Turbo'd 1FZ performance? Reliability?
Jefferson City TN
so I got a second 1FZ and trans for cheap and will be rebuilding it. Planned on doing all OEM internals. Want a little more power, but reliability is number 1. Travel regularly across country with 4 kids and a wife pulling a small expo trailer(under 1k)
Currently have 300k on my engine and no signs of dying soon so I have time to build the new drivetrain right.
Looked at this kit:
1993-1997 1FZFE Turbo Kit [1993-2007 1FZFE] - $1,499.99 : CruiserParts.net, Toyota Landcruiser Parts
Curious if anyone is running it. Performance? Reliability? I am wanting to have a reliable motor that is just. Little peppier. Doing research looks like 14lbs of boost or less is fine. Anyone have experience? I have zero turbo experience, but am willing to learn. I am comfortable working on the 1FZ and just did my HG a year ago.
Thanks,
Tommy
Questions I would have:
What brand turbo?
Where was it manufactured?
What brand bearings?
How reliable is oil/cooling delivery to turbo?
All the rest of it is piping and springs. There are too many T4 turbos on the market that can be clocked to fit the truck to settling on Chinese crap, IMHO.
To give you an idea...the last good turbo kit I bought was for my Audi S4. It was over $6k.
I'm just suspicious of the price.
That kit has been discussed plenty here
Not all that great. Cheap turbo and mediocre fitment. Terrible intercooler placement.
Im not the most well versed but known enough to suggest keep reading lots of other FI threads.
I think your goal is obtainable with the reduction to 8-10psi where a newer 1fzfe cpu could Handle it. HOWEVER your biggest challenge is going to be the fact its a 1994 and not 95-7. The VAF vs MAF and slight fueling differences will be a huge hurdle to overcome. The beat answer may be a stand alone or parallel ecu setup.
I would rather piece my own kit together with quality parts following scottryana's recipe like heckraiser did.
Ryans Recipe
Raisin Heck
I was going to go with a solid manifold for longevity and reliability. The tubular ones won't last as long and will probably break even sooner from wheeling. Link.
The turbo is also very cheap and the one part you don't want to skimp on. I would look at something made by Garrett, Borg Warner or another quality turbo brand. Something like this, maybe.
Then you have to figure out your ECU situation. The pre-95 VAF's will handle little to no boost. So you'll have to go to standalone, or piggy back. I wouldn't even bother with piggy backing, personally and would go straight to standalone, like Megasquirt. They also have kits so you can assemble it yourself and save some money.
They have adapters so you can plug the Megasquirt ecu into your existing ecu harness here.
The biggest problem is the Transmission ECU. That is, if you want to use the Electronic "power" button. The engine ECU and Transmission ECU talk to each-other. I've got all the wiring diagrams for the transmission and the engine ecu and still am not sure what some of the wires do(the diagrams don't specify)... since the transmission doesn't need a computer to operate, this isn't 100% necessary from what I understand, but will be better, since it revs out higher when the button is pressed(turbos like that).
I'm by no means an expert, but this is what I've found in my search for turbo'ing my FZJ80.
Everyone here has pretty much nailed it. That is the old CXRacing turbo kit. Even CXRacing figured out they completely botched that turbo selection. They put a 76mm Chinese turbo with that kit, which is WAY too big for it's intended use. They have since beefed up their manifold and gone with a realistic size 62mm turbo.
Your biggest problem is going to be that it is a '94. It does not have the OBDII open loop that is exploitable like the '95+ trucks that are easy to turbo. It is not impossible but you will need a standalone to take over fueling and ignition. To date I do not know anyone that has done it. I only have '96 and '97 LX's so I don't have any experience with the earlier trucks.
But with regards to stock internal reliability. I turbo's my truck at 130,000 miles and have been running 14-20psi with a standalone, bigger injectors and water/meth and I am at 168,000 now.
