I have a 96 TLC and the starter motor won't work in the morning. It starts up in the afternoon or evening with no hitches. Once started, it runs great and will continue to run and start while the engine maintains its warmth. It's been about 25-35 degrees out overnight and at first I thought I had a battery issue. The battery tests fine, holds a charge and even with a trickle charger on it over night still won't start in the morning. All my cables are tight and clean. The contacts on my starter are clean and in good shape. My alternator is functioning correctly. I've been trying to find a starter relay to test but my books (Chilton and Haynes, I know, shame on me) are oddly vague on whether or not there even is one. Has anyone else had this kind of an issue? I am tempted to just run a bypass or a larger gauge relay setup, but I'd like to not waste my money on something that can be simply fixed. There aren't that many components in the starting sequence that would be affected by a temperature shift like that, are there? Thanks in advance for any ideas.
