Ok. Everything tested great. Battery voltage is within acceptable limits, voltage drop indicates that the starter is working correctly, bench test of starter indicated that solenoid and starter contacts all functioning correctly. Cleaned everything up and put it back together. Started right up. Next morning, nothing. No crank, no start. Later that after noon, starts right up. It's got to be temperature affecting it somehow. It's possible that the wires are tired or the ignition switch is going out, but I can't get it to fail once the day warms up. Went ahead with a 30amp relay setup this afternoon (no cutting or splicing, just simple plug and play) and it started even more quickly, almost on the first crank instead of the normal three or four. We will see what the morning brings. Wish me luck. If this solution works, I'll be replacing the ignition switch, which is basically what i'm alleviating the strain from with the relay setup. And leaving the relay setup as a permanent support.
