Transfer Case lever clarfication and use.
Ghostrider I
I wear many "heads" as I have many vehicles.
Charlotte NC
'91 HDJ-80 4.2 turbodiesel, and five-speed. Ok, so when the transfer case is 4H (south or down), the CDL (center diff lock) light kicks on, right? If I press the switch, does it automatically go into 4H? Now, for in town driving it is supposed to be in 4L?
This to me makes no sense, or the knob has been replaced with a later version.
Here is the situation; when I got the truck I noticed that the lever was in 4L. Started truck, put transmission in neutral, and shifted transfer case lever into 4H. In addition, I pressed the CDL button, light kicked on. Haven't been driving it for slightly over a month, since it has been a challenge getting insurance, and some DMV hassles with registration, but Monday it finally is on the road.
Today, the truck was very sluggish, as if it was in 4L. Drove it for a bit, parked, and came out 15 minutes later. Shifted transfer case into 4L, the truck was dare I say, spirited, and the CDL light went off. What gives?
Hmm...
The CDL exists to tie the front and rear driveshafts together.
The transfer case is a two speed transmission. 4H is geared closer to 1:1 than 4L, which means tooling around town should be done in 4H, offroad wheeling in 4L.
The CDL has no effect on the gear selection in the transfer case.
Originally, Toyota designed the 4 wheel drive system so that the CDL would only operate when 4L was selected. The pin7 mod removes this restriction, allowing for CDL activation in 4H and 4L.
HTH
I get what you are saying Malleus, but 4L is more like 4H, that is why I said about the knob being reversed in its labeling. 4L is with the lever pushed forward, and 4H is pulled back. I also get that the t-case being a two speed transmission, as I had a Series I Discovery with a similar t-case. I see you are in CLT, where abouts?
Wierd. So, on my rig. I have a high/low lever, like you. But, from the sound of it my positions are reversed. (in high the range the lever is away from me and in low it is closer to me) If I am in high range, no CDL, the light is off and I am AWD. If I engage CDL, I am in 4-hi... still in the "long" high range gears. If I shift to 4-lo, CDL light automatically comes on, as does ABS. The truck will have a lot more acceleration but will top out in speed crazy early.
Try this. Drop your trans into first gear (L). Then, in both ranges, accelerate to 3000 rpm and note the speed. That should confirm which range is high and which is low.
EDIT: Here's what my setup looks like:
Lumpskie,
When it is in 4H it acts as if its in 4L and vice-versa. In addition, mine is a 5-speed manual gearbox and no ABS. After all, it is a '91.
So, you're sure that when the CDL engaged light is on the truck is also in low range? If so, I think you're right... it's reversed. If not, could the CDL sensor engagement be reversed? (will switching power and ground to that?)
Just for clarity, do you know whether you have the HF1A, part-time transfer case or the HF2A, full-time transfer case?
The gear ratio, IMS, is 2.488 in low, so the speed difference between the high and low ranges should be roughly half, that is to say for any given engine rpm, the output speed at the wheels should be less than half in 4L what it was in 4H.
I do not know what transfer case I have Malleus. How would I find out? Some details; 1991, European Spec, 4.2 litre turbodiesel six, five speed, VX model.
Should be on the nameplate on the side of the case, but in any event it should be obvious that you can select 2WD or 4WD (H/L). If not, it's full time 4WD.
I can see how the CDL gets swapped from 4L to 4H (maybe), but not how the shift fork gets swapped. I'm looking at the FSM to see if someone maybe rebuilt the case and swapped the high and low output gears. More to follow.
I'm guessing you've got the wrong TC shift knob in your truck, with H/L backwards.
Your shift knob should look like Lumpskie's. If it doesn't it's wrong.
Looking through the FSM, you have (I'm guessing) the H151F 5 speed transmission and the HF2A transfer case. The low speed output gear is the center differential housing, so the high/low gears can't be swapped. Forward shift lever position should be 4H and rearward position 4L.
This is what it looks like, in case you're interested
The small gear on the center differential assembly is the high speed output gear, the larger is the low speed gear. Shift fork no. 2 is the CDL operator; the motor actuator is what the dashboard switch operates. The high and Low shift fork assembly is is what you move with the selector lever on the console.
I agree with the statements that you have an incorrect knob on your transfer case lever 4H should be going forward and you pull down (south) to go into 4L CDL should automatically engage when going into 4L as well.
Hmm...
HTH
I believe you are incorrect here.
It is my understanding that the center diff lock is SELECTABLE in High gear and FORCED in Low gear (as designed by Toyota).
With the 7Pin mod, the FORCED activation of the CDL is removed and you are free to run in AWD in both High and Low gear (in the transfercase), as opposed to 4WD.
The distinction here is in AWD the transfercase acts like an open differential, sending power down the path of least resistance. While in 4WD, power is given to BOTH the front & rear axles equally.
We all (well most anyway) understand the reasoning behind locking diffs - without 'em you're a one legger and with one, when one wheel slips the other side grips. Well, the same basic principles apply to the Center Diff Lock. Unlocked, power goes front OR rear, whichever spins with less resistance. Locked, power goes equally both directions.
From what I read, he has the HF1A transfer case...he did say NO ABS, thus full time 4WD will not be present, easy way to see it, free wheel locking hubs (as mine has) also, you have always said 4H, then you must have the earlier HF1A that is not electronic, meaning, your lever has 2H-4H-N-4L...at some point you must shift to the right a bit the lever...it came in 70 series, but I have seen them installed in 80's...now, since you say the center diff lock light comes on, then you may have the HF1A electronic and the 7-pin mod...it is kind of weird, but you should really post pics of your actual lever to understand better your situation...
P.S. also, mine has free wheel locking hubs, but I run them engaged all the time, nothing happens, maybe PO switched them for the hub plates the full time has
Pics will come tomorrow.... As for the T-Case, when I shift into 4L the CDL light kicks on. There is no shifting to the right, just a straight down to 4H. I don't have manual locking hubs either. I think the T-case knob is new, because it is in surprisingly good shape for a truck that has close to 240,000 miles on it. Oh and panamacruiser, can you source me an OEM five speed gear shift knob? Black? Grey? I have this chrome and black "bling" knob that just doesn't cut it.
Hmm...
HTH
This seems right to me, so what portion of his answer seems off? (? Meant for @krs2fur )
What I don't get about your statement is the 'selectable' in hi-range, -as all USDM market FZJ's came, you only had the option of CDL in lo-range if you didn't pin-7 mod, even with a CDL switch.
Pin 7 mod just lets you use CDL in hi-range, or prevent it in lo-range.
As for OP, can you post a pic of your build label on the door, it should spec what trans case you have, help clarify this.
