tranny
:confused: can't afford 20,000 for a v8 swap. but need a 4-5 speed tranny. currently have a 3 speed but want more top end. what do i need for a 4-5speed tranny? waht is the best set up? wpuld perfer a 5 speed but i have a buddy that has both.:confused:
A four speed will cost significantly less than a five speed- few hundred dollars vs. a few thousand.
For a four speed (h41, h42), you'll need a four speed bellhousing, tranny, '74 'case input gear, rear axle bearing from a datsun, and your drivelines extended/shortened. Also- you'll need a different speedo cable and brake cable (the four speed units will work) and you'll have to extend your 'case shifter, and put a few new holes in your floor (IIRC).
For a five speed, you'll need a fourspeed bellhousing, tranny/case (since your existing case won't work), different yokes on our extended/shortened drivelines, a craddle mount for the tranny, extended speedo cable, and a different ebrake setup. New holes in the floor.
20K for a V8 swap? How did you come up with this number?
Even buying an 8K or more souped up V-8, I would still think you would have a hard time hitting 20 k...
As others have said, your top speed will NOT increase with a 4 speed. Final drive on a 3 speed and a 4 speed are 1:1. Change tires, regear the differential, go to an H55. Cost increases with each item.
the $2000.00 was low price given by a vendor here. high was $30,000.
going with bigger tires 35"s or 36"s currently running 31"s with 4 " lift
To get 'top end' speed, or lower rpms at highway speeds
Transmissions
H55
700R4
Nv4500
That is about it for trannies. As others have said, bigger tires, higher gears. Gears are not easy to find for LC axles.
With my Fj55, 35" MTRs, stock 2F engine, at 60mph, I was turning 3k rpms. Now with the 350TBI/700R4 setup I am turning around 2k at 60mph with the same tires and gearing.
have a 72 stock motor and tranny with a 3 speed with a 4" lift all stock. will not do over 55 mph but would like 65 to 70 mph.
have decided to put 34 maybe 36 imch tires on my little green beast will let you know what i find out.:beer:
Tires that big and you are REALLY gonna be hating that 3 speed.
If you're not planning any serious off roading, I'd recommend an upgrade to an H42 tranny. Fairly straight forward, even spacing between the gears, fully syncronized, and enough improvement in the bottom end to make up for the rubber overdrive.
I just had my 64 fj45 on 32s and the three speed up to 80mph on Saturday for S&G, so theoretically you don't need to modify ANYTHING to go as fast as you are interested.................except a rebuilt stock engine.;p
