Trail Kit- opinions wanted
Brevard, NC
Website
mofj40-1968.tripod.com
I might be going on a 3-4 day trail ride/camping trip in a couple of weeks. It will be with 1 other 40 and several assorted rigs. Most are mildly modified- 33" tires, maybe a locker here and there. The 40 I'd be going is the most built of the group with SOA, hysteer, aussie lockers, 36s, winch, etc, and should have no problem helping me bypass any section too rough for my rig.
My 40 is a 68 with 2.5 lift (unknown brand) and 33x10.50 boggers. No locker yet, otherwise stock with F engine and 3 speed, vac actuated T case.
What parts would you consider "must-have" for a trail kit. The trails we'll be on won't be real technical, but will be in the middle of nowhere, with zero chance to source replacement parts. I've been given the opportunity to pick through a LARGE cache of spare parts, so what would you guys suggest?
Also, I've aready got a highlift, straps, chains, etc. Just looking for 40 specific parts suggestions.
Thanks in advance.
Spare Birf, 90 weight oil, JB weld, Hub socket, Molly grease, brake fluid, assorted metric bolts. Make sure they are longer than you think, Hack saw blade, air pump, tire plug kit, first aid kit, sunscreen, and some disposeable gloves. Bottle jack, good flash light with spare batteries. A few sections of different guage wire.
u-joints, if they are the same for both shafts, then just one spare...or perhaps a complete spare rear shaft...
pinion....with inner bearing...if you HAVE to, you CAN install just the pinion and run it....been there, done that, much lighter than carrying a complete chunk
inner front axles, two birfs (68 is coarse, and not so strong - axles are in case the splines bugger when the birf breaks)
brake/clutch fluid, 2.5 gal 90wt, spatula, pre-pack the birfs with moly and ziplock them, tube of wheel grease, garbage bags (can save 90wt that way too for reuse, if ya had to...BTDT)
break line cap (old brake line, cut it short with the fitting on there, bend it over 3-4x to seal it....if you blow a line, put the cap in at the master to block that circuit...fast/easy fix to get moving again)
The key will be items that are specific/odd to your vehicle...the tool bag I carry will repair ANYTHING on my rig....
At a certain point, carrying too many spare items adds unnecessary weight and increases the chance of breakage....lol
I would love to have all the items that are listed in my rig and hope to some day. But really, are the guys you are going with driving cruisers of the same year or close? And are they just going to leave you there with a broken cruiser?
Talk to them about what you should bring and tell them about your concerns and see what they say.
I think a helicopter would be a great item to bring along so you can airlift. You can only bring so much or you will no longer have any lift on that cruiser.
What ever you bring, make sure it is anchored and is not going to go flying around as you wheel, or worse, roll.
if you can't get the essentials bring lots of cash or beer they work really well. I carry just about everything that's been mentioned above and still find that I don't have some parts that peopleneed to fix thier 40 when they brake. You haven't been wheeling untill you've broke on the trail. Have fun and good luck.
Here's my list:
#1: spare tire. Break it down from there by sections and you'll get a better response
010-engine electrical-jumper cables,points, cap, coil, starter, alternator, electrical wire, connectors, electrical tape
030-engine-extra oil, starter fluid
040-cooling- coolant, water, belts, hoses, clamps, duct tape, permatex, water pump,radiator stop leak (ONLY if you ABSOLUTELY HAVE TO-middle of NOWHERE) heater hose
050-carb- carb cleaner,fuel filter, gaskets, rebuild kit, collector gasket (if you run headers) fuel pump, extra fuel line, brass fittings
070-clutch-m/c and slave rebuild kits, brake fluid, hydraulic hose
080-tranny-extra gear oil, drain plug
090-transfer case- same
100-rear axle-same, gaskets/permatex, 3rd member, pinion and axle seals, lug nuts and studs
101-driveshaft- extra bolts and u joints, complete shafts
102-tires-lug wrench,patch kit, air source(compressor or tank), tire guage, valve stems
110-front axle-locking hub, spindle, birfield, knuckle studs
120-steering-belt and fluid, main steering shaft
130-suspension-couple of spare u-bolts and spring anchor pins, spring center pin, extra shackle
140-brakes-m/c and whl cyl kits, brake fluid, hoses, generic brake line, brake cleaner
general-fire extinguisher, first aid kit,bailing wire, all-thread/ready rod, plumbers tape, repair manual, hand cleaner, rags
For the record, I carry about twice this much, and had to lift the rear of the truck 1.5" more than the front to get it near level!
And then there's the tools and the rescue equipment!
Here's a link to a previous discussion:
http://www.pirate4x4.com/forum/showthread.php?t=265657
What qualifies as the "middle of nowhere"? How far will you actually be from any sort of support? (Trail miles and road miles.)
What type of trails will you be dealing with, and what sort of obstacle? Water crossings? Mud Bogs? Nasty rocks? Hill climbs? Kinda early most places for deep snow..
What sort of distance will you be covering?
Mark...
podunk arkansas- autozone within an hour of the blacktop, but no source for most cruiser parts.
Worst case scenario, I need to limp to the trailhead. I can get a ride home with the other 40, and retrun with truck and trailer to haul mine home.
Trails will be through Ozark National Forest- Mostly mature hardwood forest with steep ravines everywhere. Not high in elevation like those of you on mountain time, but very rugged. Spend most of your time going up or down. Definite stone bed creek crossings, though not more than a foot or two this time of year. Rocks in the area are mostly limestone or granite slabs, boulders not likely. Mud likely, but not excessive. Forest is 1.2 million acres. 3-4 day trip, in one side and out the other.
Keep in mind this trip is being planned by a group of very mildly built jeeps. Not many will be running lockers or tires over 33". The core group makes this run at this time every year, with some variation in route.
I used to run a fullsize bronco and a tacoma, but in both cases parts are available everywhere. This trip will be a little tame compared to what I used to do, but my cruiser is untested so I'm easing into it. I really don't want to be a days trail ride from blacktop to find out I have a weakness- guaranteed to be the one part I didn't think to bring.
To break down my question a bit further, what are must-haves and what would you throw in only if you have space?
Thanks for the responses so far.
how come nobody mentioned a good strap for being pulled out (if nothing else works).
