In order to replace the plugs you need to remove all the pipes you see in the photos including the intake manifolds. Sounds bad but you do it every 20k miles or so if you use proper plugs and unleaded fuel. Oil and filters takes an hour so you do it yourself. No factory guarantee on this baby! Sent from my iPad using IH8MUDJust out of curiosity, IF you were to have someone do the service on it, say, change the spark plugs, and oil change, how much more do you think it may cost over the stock, IF you could find a shop to do it. You can give the difference between V8 cost and V12 cost as a percentage, since we'd be trying with all the fingers on both hands to figure out the exchange rate of your dollar and the USD over here.![]()
Guys
I'm busy fitting a V12 into a 100GX Cruiser. It is being fitted with a 6 speed auto box and two T3/T4 turbos. We'll keep boost to .4. Has anybody here fitted a V12 into a 100 or and 80 series? Does anybody have some experience with the V12's and / or putting turbo's on one?
Dion
I would love to get v12♡..is it patrol. ? Posted via IH8MUD app
Generally, toyota alternators run a "sense" wire which monitors the output of the regulator at the battery terminals or at the fuse box. This is done to overcome cable resistance(voltage drop), so the output of the alt may be 14.4 at the alt terminal and 14 at the battery etc.. If the sense wire is open circuit the regulator goes to 16+ volts, I don't recall it dropping after, but check the sense wire is powered.Hi Guys
We need some help, everything worked fine but since we took it to the dyno it keeps on blowing the regulator on the alternator. Volts are fine at just below 14 and as soon as you increase the revs the volts will go up to about 16 or 17 and the it falls to about 9 and the alternator light comes on.
Any ideas?
