paging @87warrior - are you still looking for steering knuckles? This is a smoking deal
I appreciate the info, but I called and they told me local pickup only...VIN check on partsouq for your original windshield fitment.
If you're on an LC probably the windshield threads in the subforum are a good source of fitment info if you'd like to upgrade that to an LX windshield.
There's OEM green tint, night vision glass, LX bronze tint and maybe a few others
I’ll give Eric a call, if Serra Toyota is unable to ship my order I’ll have less than a day to give a shot to Marietta Toyota!I appreciate the info, but I called and they told me local pickup only...![]()
Care to share your parts list? I may need to grab all vac hoses as well.got radiator, all cooling system hoses with new clamps, all new vacuum hoses under hood, new axle with drive flange, bunch of misc parts.
There are differences in some of the years, but here are the diagrams and parts for a 2004Care to share your parts list? I may need to grab all vac hoses as well.
P/N | Quantity | Price Each | Description |
1640050360 | 1 | $ 283.54 | Radiator |
852140E050 | 1 | $ 5.17 | Back Glass Wiper Blade Refill (Rear) |
4351260171 | 2 | $ 50.58 | Disc Brake Rotor (Front) |
9091602586 | 1 | $ 31.75 | Serpentine Belt |
2382950070 | 1 | $ 21.20 | HOSE, FUEL VAPOR FEED |
1736150010 | 1 | $ 13.26 | TUBE, AIR(FOR IDLE-UP) |
1734550080 | 1 | $ 12.26 | HOSE, AIR, NO. 5 |
1734150170 | 1 | $ 17.78 | HOSE, AIR |
1703050070 | 1 | $ 29.32 | HOSE, NO. 1(FOR IDLE-UP) |
1226250080 | 1 | $ 10.99 | HOSE, VENTILATION, NO. 2 |
1226150050 | 1 | $ 14.21 | HOSE, VENTILATION |
1220450030 | 1 | $ 6.40 | PCV Valve (Left) |
90915YZZD3 | 1 | $ 2.80 | Engine Oil Filter |
1634650010 | 1 | $ 3.26 | GASKET, THERMOSTAT |
9091603100 | 1 | $ 14.84 | Engine Coolant Thermostat |
9046713054 | 2 | $ 0.82 | CLAMP OR CLIP; CLIP |
1626150090 | 1 | $ 4.48 | HOSE, WATER BY-PASS |
1657150150 | 1 | $ 18.29 | Radiator Coolant Hose |
9046641008 | 3 | $ 4.21 | Radiator Hose Clamp |
1657250150 | 1 | $ 25.90 | Radiator Coolant Hose |
9046743002 | 1 | $ 3.56 | Radiator Hose Clamp HOSE(FOR RADIATOR INLET); HOSE(FOR RADIATOR OUTLET NO. 1); RADIATOR HOSE, NO. 2. |
4342260070 | 2 | $ 1.30 | Drive Axle Shaft Flange Gasket (Left, Right, Front, Rear) |
4342160060 | 1 | $ 41.39 | Axle Hub Flange (Left, Right, Front) FRONT AXLE OUTER SHAFT, LEFT; FRONT AXLE OUTER SHAFT, RIGHT. |
9031147027 | 1 | $ 9.44 | OIL SEAL; SEAL FRONT DRIVE SHAFT, LEFT; OIL (FOR DIFFERENTIAL SIDE GEAR SHAFT). |
9031147013 | 1 | $ 10.28 | OIL SEAL; SEAL |
4343060040 | 1 | $ 351.90 | CV Axle (Left, Right, Front) FRONT DRIVE, LEFT; FRONT DRIVE, RIGHT. |
I am just about to place my 3rd order. Shipping is at $55 (free) but soon after I place two headlights , the shipping becomes freight and the $55 becomes $300. So glass might add an insurance.Thanks @Hayesthebuilder
Saved $$$s. Btw, Eric replied to me saying they are canceling glass orders. No reason was given, probably shipping issues. Make sense.
forum.ih8mud.com
Nope.. no core on this one.. its brand new. Core charge are usually only for Reman parts.Just factor in that they do require the core to be returned for the core charge to be refunded.
