toyo tires
El Paso TX
hey guys!
i have some questions about toyo m/t tires.
1. are 315s too heavy for stock gears?
2. why are they so heavy?
3. how do they compare to bfg m/t and goodyear m/t or any m/t for that matter? i want you guyses opinions.
4. should i mount them on 8in rims or 10in rims?
5. will one fit under the truck as a spare?
6. if a tree falls in the middle of a forest and no one is around to hear it does it make a sound?
7. does the water really go the opposite direction in a drain in australia?
seriously though your thoughts and info will be appreciated:cheers:
hey guys!
1. I think my 285's are pushing the limit of stock gears on my setup.
2. Multiple plies, thick carcass, made to take weight.
3. Quieter on highway than most M/T's, better all around than BFG in my experience, I have never run the Goodyears.
4. My 285's fit perfect on the stock 8's and 315's should be OK on 8's, I would worry about rubbing issues going to a 10.
5. 285 fit under with a little clearance to spare, probably just enough for a 315 (check first and don't trust me).
6. Ask the damn squirrel that just lost his home.
7. Yes, according to the Simpsons.
1. Agree
2.Ditto
3. Have experience with GY M/T's and BFG M/T. Toyo's are by far the best.
4. I read somewhere in a post that the 10" rim does create additional rubbing.
5. Spare no problem for me. When I go 315, I plan on doing the "spare tire mod"
6.Ask the bear who wiped his ass with the rabbit after the noise scared the poo out of him.
7. No, just a Urban legend.
I don't have Toyo's but run with guys that do.
  1. Coincidentally, one of them runs 315's on stock gears. IMO he does alright considering it's quite "hilly" here in SD. Although he may say otherwise.
  2. They have quite a bit of meat on them = weight.
  3. I have BFG MT's on my Suburban and like them. That said I'm seriously considering the Toyo MT's as my next tire.
  4. They work mounted on a stock rim.
I wanted 285 Toyo's but got the Cooper STT's due to price and not wanting to re-gear. I have been very happy with the noise and performance of them. They have a thinner sidewall but I just don't run too low of air pressure. I only go down to 20 psi.
I have a set of 315's on with stock gears and I would buy them again in a heartbeat. nuff said
Buck Buchanan
I JUST WENT FROM 315 GEOLANDER MT'S TO TOYO MT'S AND I COULD FEEL A LOSS IN POWER FROM THE EXTRA WEIGHT.... IVE ONLY HAD THE TOYOS FOR A FEW WEEKS NOW BUT SO FAR I REALY LIKE THEM. THIS IS MY DAILY DRIVER AND THEY RIDE MUCH SMOOTHER ON THE ROAD THAN THE GEOLANDERS. BUT THE EXTRA LOSS IN POWER HAS PUSHED ME TO REGEAR 4.88'S GOING IN SUNDAY:cool:...
I was a MTR user for about 3 years. When I went to 35" MTRs my troubles started. I ripped 3 side walls in less than 18 months. The Goodyear MTRs were getting expensive. Last September I made the switch to Toyo MTs. I've been super happy with them. I've been on the Con back and forth and you could not tell by looking at the tires. The MTRs would always come back with chunks missing from every were, sides and thread.
I'd recommend the Toyo MTs in a hearbeat.
Alvaro
1. At 6,000' with Toyo 315's and stock gears, the truck NEEDS 4.88s
4. You can mount them on 8" rims
5. Doubtful, but you can try it. I wouldn't
FYI, you and I wheeled together in Ruidoso and my truck has stock gears with 315 Toyos. The drive back up the mountain from Three Amigos trail was painful. The multiple trips from the camping area back up the hill to town was painful.
I like the tyres and they seem to be holding up better to rocks than the BFG M/Ts they replaced but the jury is still out because I ran the BFGs for 3 years and the Toyos have only seen a few (4 or 5) outings.
-B-
I had a 315 MTR mounted in the spare tire carier (slightly worn) and it worked fine. It looks like it rubbed some on the panhard with minor offroad use when I took it back off. I ended up takeing it off because it just looked funny kind of like the 80 was wearing a diaper. If you do serious offroad I probably wouldn't suggest it.
same, it rubbed my panhard. it barely fits. rear bumper not needed but highly recommended.
I run 315 Toyo's and am definately going to 4.88's. Off road I do pretty well. On the freeways & hills, not so much:crybaby:.
Here are a couple of pics of one in the spare tire hole. It doesn't rub my panhard at all. It rarely rubs the ground either but I am running a 6" lift. I would only consider storing it under there as a temporary solution.
5. If you need 315's, then you need to not have any spare in the stock location from a clearance perspective.
-B-
i do remember you. good times up there.:cool:. ive been meaning to pm you because i remember you had toyos. also to see how youve been. thanks for the info. pm you later if you dont mind.:cheers:
thanks for all the info guys! im definatley getting the the toyos!:bounce: my tlc is not my daily driver. so i think i can wait a little bit for gears.
thanks again:cheers:
I ran 315 Toyos with stock gears for 18 months. I'm at 3800 feet. It really wasn't terrible in town or on the trail. On the interstate it sucked. I couldn't get into OD until after 82 mph. And it wouldn't hold it on hills. I regeared to 4.56s as I bought them used fairly cheap. I've got about 4k on them now. I would not want to go with 4.88s due to the highway RPMs. I'm just about perfect with 4.56s. I'm running 2800 or so RPMs at 80mph. Now, if you in a state where the speed limit is only 65 and that is where you spend all your time then it makes more sense to go with 4.88s as most on this list do. Alvaro is right. These tires are bulletproof in the rocks. I do have some chunking on mine but it was from driver error and extremely sharp and jagged lava rock. We have brutal lava rock in Idaho. Sharp and Jagged. These tires have held up great to this environment.
thanks for the input. im afraid of the chunking but thats possible with all tires. im going the getting them then.:cheers:
His truck looks very sweet, it looks taller and ready for anything!
Now it looks like a rock crawler!:o
