Top 3 pick for 37" tires
bfg km3? they look like a crawler type pattern
Steel I'm assuming? The alum wheels are around 22lbs and the steel are like 35-40lbs. Was trying to keep the rotating mass down if possible
No they are aluminum I don't remover the brand I'd stay away from steel they usually don't balance great. My buddy has 17x9 4.20 bs I'll find out brand
I'm in the market for 37R17 TrXus radial MT's. Haven't read a negative thing about them in quite a bit of research. They may not last as long as some others but they are said to grab a variety of terrain very well.
Real quik, I cannot find 37s to replace the 37s I have now on 16in rims, what other rim can i run in 17? im told 37s for 16in rims have been discontinued
Ya there really aren't an 37s in a 16 from what I've been researching. Kinda sucks I have to buy new wheels to go to 37s
  • Like
Reactions: RFB
Ok, just looked but they make it in 17"
In another thread you wanted bias Trepadors... well here is the radial version.
How worn are your current tires? When I went to 17s I was able to more than cover the cost of the new wheels by selling the old set.
My tires are a month old so I'm taking a hit on them. I did just find some bfg krawler blue labels for sale locally that have 1k miles on them. He wet to 40s and selling for $300 a tire and has 5. So I'll go that route if I can grab them before someone else.
It seems the centered wheels fit best on a 80.
9" 4.5" BS
8" 4" BS
7.5" 3.75" BS
9" 4.5" BS
8" 4" BS
7.5" 3.75" BS
Hmmmm. Got ya. I wanted to stay wit an 8" to try to keep the bead on a little better when aired down but don't see tha in an aluminum wheel. Wonder how the 9" will do vs the 8"
Plenty of 17x9 4.5"BS
Could just do tundra wheels with like 38mm spacers.
Interco - Super Swamper TrXus radial MT can be had in 37x12.5R16 as well as R17.
I don't believe you would be liking Krawlers after a 15 hour drive, but that's just my opinion.
Just like written above... on a 8" wheel if you stay between 4" to 3.5" BS you should be fine.
I don't believe you would be liking Krawlers after a 15 hour drive, but that just my opinion.
You are probably right, I may end having to trailer the truck if that's even a thing. Now my drives to go off-roading are 3-4 hour drives and that's probably even going to suck.
