Tools and Jacks - pics???
Flagstaff, AZ
My '71 is just about out of my garage from being there for the last 12 months with a few updates/upgrades.
Given it's summer, I would like to take the top off and make it my DD again.
Can you all show some pics of where and how you keep your tools secured and where you mount your Hi-lifts?
(Mods - I am posting here rather than chat to get a more focused crowd of 40 owners - hope this is OK)
Thanks,
Brian
tools and jacks
I have mounted a Tuff box in the rear bed as well as some surplus ammo cans. The High Lift jack is mounted to the rear tailgate with a bolt. I have pictures posted on the below website.
Mike El Paso TLCA 8009
1985 FJ-60
1977 FJ-40 http://community.webshots.com/user/mep1811
IIRC there was a thread on here about high-lift attachement ideas earlier this year that had numerous photos and ideas.
Personally, mine is attached to a rear Con-Ferr spare tire/dual gas can carrier.
as for tools and such, I have a Con-Ferr rear bench seat that has storage under it and I use the rear most storage (it has 2 storage bins) to put tools, spare parts, fluids, etc. into. I also have a nice tall 50cal ammo can set into one of the gas can carrier mounts that contains some misc items as well.
mine is attached to the rack on top of the roll cage
High Lift Mount
I attached mine to the front tow hooks supports. It features removable bolt-on, lockable, and rattle proof.
Under the jack is a valve rocker arm spring which you compress and then slide the pin shaft through to secure - using the existing holes of the jack and the holes drilled in the mounting plate. The lock just goes thru another hole drilled in the shaft of the securing pin.
I put some heat shrink on the jack handle to aid grip and not rattle - with a plastic tie to hole down.
- it's good to see all the ideas.
is this your creation or did you buy the mounts? great idea. have any photos that fully show the jack installed.
here is mine.
I agree w/ Wantatlc, I like your design. Can you send more pics and let us know were you bought it or how you designed it?
Thanks!!!
Brian
Guppie,
I like those tuffy speaker boxes. Are they big enough to put a lug wrench, tow strap, and jumper cables in there?
Is the back of the speaker enclosed so they don't get damaged?
I saw those for the first time yesterday and intrigued me - nice to see one mounted.
Brian
Full Frontal
This is the mounted on the front look. I must say that folks tend to look at the hi-lift jack more than anywhere when I'm approaching.
I just made the mounts in our corporate AAA (Arabian Automobile Association) facillity - which is really nice (for $50 / year membership).
Actually, the vehicle is in one of the AAA bays - before I put the top back on.
The original intention was to put thick rubber pads on the insides of the mounts to stop rattle - but it wasn't necessary in the end.
I was an inch away from mounting the jack in an upright position on the door step - between the vent and the passenger door - still might try it using the running board under support to build on.
The rear jack mount / storage has got to be useful / practical - but not possible with ambulance doors.
Brian,
yes, the speakers are protected from the other stuff in the box, the boxes come with another panel that protects the speaker location. You could fit all of that stuff in there, no problem. I like them alot and along with the rear box I can carry a bunch of stuff. I mounted marine boat speakers in there, ran some dynamat inside to help with rattles, sound great.
Noah
Thanks Noah!
I'd still love to see more pics of other peoples solutions to both storage and jack mounting, but think w/ your speaker/storage tuffy and DesertPat's idea I think I have figured out what I am going to do.
Brian
i have my 48" hi-lift mounted on the passengers side step in an upright position. boring but practical... doesnt get covered in too much crap as guard protects it from most.. i put a couple of bolts through the step, coming upwards, attached with a thin nut and predrilled through the thread of the bolt so once hi-lift sat on the nuts (bolted up tight), the bolts lined up with holes on base, i could then put a clip through the pre drilled holes in thread and lock it over...
made a clamp to utilise the window frame mounting bolts... sits fine with no vision obscuring...
when my good 40 is fully resto'd, i plan to use a hi-lift cover, got one in the garage.. jackguard i think.. protect from weather on my 40 jeep styles.. :D
i realise this'll be a common placement for them, but thought i'd chuck it at ya anyways... sorry if youre asleep.....:rolleyes:
sorry, no pics of it. trucks out at the farm at mo..
great... now go back and delete posts #16 & 17 :)
but seriously, how the hell do you get to the bolts holding the tow hooks if the frame is boxed in on the drivers side becuase of the powersteering mount??? I like this idea better than mine, but I would say my tow hook is there for good.
Deleted the posts just for you Wantatlc! Meant to do it, but was late for a meeting when I posted.
DesertPat said that he is going to send some other tips on how to improve his own design. I'll post up, if he doesn't, when I get them.
Brian
ya know you don't have to use those existing bolts. for a similar design why not fab a bracket to hold them in the same position, but which would allow you to bolt through your boxed frame or other convenient area?
