Toggle switch panel help?
Central valley (Cali)
Ok I searched ?but nothing?any ways wanting to set up a multi switch panel,but wanting to see if anyone has some pics of what they've done ( for lights ,lockers,and other stuff?) any help is great thanks
James
for what it is worth, I went to Pep Boys and they have a very cool toggle switch that, on the tip, turns red when in the on position. I installed 4 of these inmy fj40 (rear electric gas tank pump, front baja lights x2, rear back up light, overhead light). they are affordable, should handle all of your power (AMP) needs, and are noticable at night and a reminder if in the on position. I used existing holes on the dash, so no real cool panel, but the toggles are cool.
If your going to power anything that draws significant current use the switch to control a relay. It a lot easier to run 18 gauge wire than 10 or 12, and your switch should last longer.
I made up some plates for a guy on the boards to fit the contura switches, he wanted it to fit over the stock location. I have some extra's that were a little to tight on the switches, file em a little and they would work great. they were polished stainless and made to hold 6 switches, they didn't have mounting holes though, we stock other plates that are stainless to hold 1-6 switches, but they are a little larger around the edges to accomodate mounting holes, won't fit in the stereo hole, but they can be mounted anywhere. that's flat and you are willing to have a hole behind.
Are you using the ash tray for anything? The one shown is just a piece of aluminum plate as are the other gauge clusters.
Waytek wire or the wiring site in the outfitting FAQ are great for clean, functional and fairly waterresitant swithces. Use relays, the expense and hassle is well worth the piece of mind and increased performance. Running lots of amps through dash mounted switches usually ends up in melted components, fires, or ashes. At the least you end up replacing switches a lot more often.
painless wiring makes them too, pricey but nice, i used sheet metal, drummel and toggles from autozone and made mine. looks good
Hey thanks guys ,gave me a few ideas.
James
