ahhhhhhh, never thought about drag racin my 60 tbhI'm talking about those times when you really wanna get moving quickly so you rev it up like you are about to drag race and have to slip the clutch to keep from stalling. I avoid doing this.
Thank you, good to know.This chart is wrong. H42 and h55f do not mirror gear ratios in gears 1-3. See link TLC FAQ - 8.1 Transmission & transfer Case Ratios (All :1) - https://www.cruiserfaq.com/08-01.php
This chart is listing H41 B,F,2H Gear ratios as an H42.
The H41 for certian cruisers will mirror h55f gears 1-4,
The h42 FJ60's first gear is 3.555:1
Edit: it may not be "wrong" but your link is listed on an Australian website. Who knows what they have over there. For US spec the h42 and h55f are 90% different with the transmission casing being the only compatible part that im aware of.
You will with your new swap.ahhhhhhh, never thought about drag racin my 60 tbh![]()
If your carb and timing aren't set up right you'll definitely notice it. At least I did. I was tired of messing with my carb all the time and chasing this very issue so I went ahead and desmogged and put in a Sniper after I did the H55F. I'm also running headers now, but I'm not sure how much that is affecting things. With 33s (actually 32) the sniper, 4:11 gears, and an H55F this truck is probably the best it will ever get outside of dropping a diesel in it. I think maybe a true 33 in a narrow 9" would be the top of this set up. I can put it in 1st and release the brake and clutch, never touching the gas, and it will start on a steep incline against a curb or a rock and crawl right over it with no persuasion from the throttle. I'm pretty satisfied. 1st and 2nd do come and go pretty fast in town, but it's not a deal breaker for me.It doesn’t bother me. It can roll off in 2nd with a 2F and 3.70 gears. 4.11 would be second gear starts for sure.
My H42 also shifted easier between gears. With the gearing closer together, it just made in-city driving much easier. I'm always fighting a bit with the gearing on the H55 when driving a lot in-city. I'll probably keep the H42 in my next land cruiser. But I do really like traveling long distances and being off-road with the H55.
Thanks! I'll keep you posted. I'm waiting on my engine now but will probably pull the Tcase off the truck now and get it mounted to this transmission in advance. Once the engine arrives it will be full on swap time! Can't wait... if you're needing a Supervisor for the job or a tool handler. HMU...you're pretty close by. I'm around till end of the month. GLW the swap
gnna rebuild the T-Case while apart ya? Also, great time to do the Clutch... im no expert jus passin on what was told to me.Thanks! I'll keep you posted. I'm waiting on my engine now but will probably pull the Tcase off the truck now and get it mounted to this transmission in advance. Once the engine arrives it will be full on swap time! Can't wait.
Yes, I got the t case rebuild kit from Kurt. I’ve also got a brand new clutch and will be having the flywheel resurfaced while everything is out.gnna rebuild the T-Case while apart ya? Also, great time to do the Clutch... im no expert jus passin on what was told to me.
wooooooooooooooooooooooooooo excite!!!Yes, I got the t case rebuild kit from Kurt. I’ve also got a brand new clutch and will be having the flywheel resurfaced while everything is out.
@cruiseroutfit Im getting ready to reassemble the t case on to the transmission and have a quick question. In the small plastic bag you shipped that has the 5th gear oiler, there are also two O rings (see picture below for clarification). Where do these go? Thanks in advance for the help.
cheers, James
@cruiseroutfit I got this swag with my last order that I haven't figured out. It's like a rubber patch with Velcro. It's cool, but what's it for?
