Tire Pressure recommendation
Once you leave the pavement drop to 20-25 PSI, the ride will be much smoother and more comfortable. If you need more traction you could safely go down to 15-18PSI without issue. I ran these PSIs with success when I previously had OEM wheels and LT285/65r18 on my LC.
Can I assume that the RCTIP for the LT285/65R18E Bridgestone A/T Revo 3 tires on my stock 2019 is also 42psi F/R?
Road tripping next week and will be hitting some logging/rutted roads where we're going. Is 42psi best for that? Should I air down some then go back to 42 for highway?
Thanks for this all this amazing help, great thread.
1. Yes. The RCTIP for ALL LT285/65R18 tires on the LC200 is 42psi F/R.
2. In my opinion (and there are many extant on this forum), if you can comfortably travel offroad at or above about 30mph, there is no need to reduce tire pressure. However, if you want to air down at slower speeds, or just because you want to, my rule of thumb is to air down to 1/2 (half) your RCTIP - in your case, that would be 21psi. Your personal experience and preference would guide you to pressures above or below that starting pressure of 21psi.
3. Yes! By all means re-inflate to 42psi when steady travel is possible above about 30mph. Don't forget to re-adjust RCTIP when tires are cold - preferably after sitting overnight.
Please bear in mind that when aired down, any sudden shock to the tire - like a rock, curb, branch, etc. - if struck at speed faster than a crawl, could easily result in tire failure. The key for aired down travel is slow and steady.
HTH
I run an odd size tire. Dug around some and found a 'rule of thumb', which is temperature based. Increase your 'cold' pressure until your 'hot' pressure is 10% more. That is the minimum cold pressure you can run. Since the TPMS reports relative pressures pretty repeatably, it only takes a few days of experimentation to find the floor. After that season with pressure until you like the ride.
For me 35 psi is the floor based on load rating. 36 or 37 is the floor based on tire psi change, and 37 is where it rides best.
All provisios and at your own risks apply.
Exactly this and the chalk test are the best methods for dialing in pressure.
P285/70/17 AT3 117T here and have been playing with this for some time.
Its important to note that "cold" pressure should be measured at ambient temperature.
When inflating in my garage, its often 20 degrees cooler than ambient. The pavement/highway will also be significantly hotter than that.
Rule of thumb here is 1PSI gain/loss for every 10 degrees F.
For my ideal 34-36 "cold", im inflating to 32-33 in my garage. The pressure is stabilizing at around 36 PSI which is my target.
Anything above 38 at temp is starting degrading my ride quality.
You want no more than a 10%-20% gain from the heat/friction at "hot" but it also does not help that ambient is varying by 20-30 degrees F daily in Texas...
Ive continued to do more testing of my setup and im beginning to realize ive probably made a mistake going to P rated.
In order to achieve the best ride, I'm sacrificing a lot of stability.
Testing at a cold 30 PSI made me lose a lot steering control to the point I was feeling the wheel wobble on turns.
Scary to say the least given it was no more than 15-20mph and it felt as if the sidewall was giving in on my inside wheel.
Im starting to think that this vehicle is just too heavy for my tire choice, and im running "light" with no third row and no occupants.
Someone had mentioned this before in a comment and I think I agree.
At least this is my observation running such a high sidewall.
If i were running a leaner profile ratio, I doubt these effects would persist due to the reduction in moment arm of the forces applied.
And all of this is happening well above the recommended inflation for this spec.
It would make sense that a stiffer tire in a E load, inflated to around half its maximum pressure would give me an equivalently compliant ride but with added rigidity. I would love to be able to do some comparison driving with anyone in my area.
I also recognize that with no occupants and less weight than "stock" there are some effects from being over-sprung. This was the same in my 470.
The more loaded the springs are, the more AHC can have an impact with adjusted damping.
Any help / experience / advice is appreciated, so let me know your thoughts.
Thanks!
HTH
Wow, amazing info as always, thank you for all of the facts and wise opinions. The possibility of too much speed at low psi is a very good thing to keep in mind, Prost.
@gaijin
Would this apply to a 285/75/17/E BFG KO2? @gaijin. Thanks chief!
Yes. Since the KO2 is also an LT-Metric size LT285/75R17, the RCTIP is the same on the LC200 @ 37psi F/R.
HTH
The Recommended Cold Tire Inflation Pressure for the 275/65R18 tires on your 2010 LC200 is 33psi F/R.
HTH
@gaijin - what if this same set up(tires and wheels) were on an lx570? I assume it would still be 33psi?
wildpeak 275/65R18 116T on 2013 LC200 wheels mounted on an 2009 lx570
thanks for your wisedom!
Usually the lx570 and lc200 RCTIP is different, except when they are both below the threshold of the tire type. The wheel it’s on is irrelevant.
The RCTIP for the Falken Wildpeak A/T3W tires in ISO-Metric size 275/65R18 SL 116T on your LX570 is 30psi F/R.
If the RCTIP feels mushy to you, feel free to use 33psi, but it is not required to meet the Load Limit requirements for the LX570.
HTH
Michelin Defender LTX M/S 285/60R18 120XL BSW on a 2015 LC?
The RCTIP for those 285/60R18/XL 120H tires on your 2015 LC200 is 33psi F/R.
HTH
Can I ask the RCTIP for 285/65/18 Mickey T Baja Bosses on 18” TRD BBS wheels? 2021 LX.
Don't know whether you have the Baja Boss M/T or A/T version, but RCTIP would be the same:
The RCTIP for those LT285/65R18 tires on your LX570 is 37psi F/R.
HTH
Better re-check your interpretation of the tables for Extra Load (Reinforced) ISO-Metric tires...
Well...guess I'm not as good at Excel as I thought I was. When I fixed the last error you pointed out I caused another issue with the XL table. That's what I get for making a quick fix and not a good one. Updated the table.
