Hi all. Im running 34" Goodyear Wrangler duratracks on my 80. Loaded light. 2 people and about 150lbs of gear. Does anyone els run these and if so whats the optimum highway tire pressure?
and Bob's your uncle.
The technical way - The result are surprising as most run too much air.
Back from the deadMost people are running on the center of their tires because of load rating tables and getting a nice harsh ride out of it.
I was running BFG ko2 in a 37 at 25 PSI on an 8.5” rim. I’m running my new STT Pro at 32, because that tire is really soft riding, and at chalk test it is too soft. Easy enough to see here.
Anytime I hear about 35+ PSI I just shudder. I suppose folks who can tolerate that also like OME shocks, but then we are still living in a world where people blew out cheap tires on 2nd gen Ford Explorers and now we have TPMS as yet another Big Safety overlord.
Totally agree, Run my 37s at 27Lbs on the streetMost people are running on the center of their tires because of load rating tables and getting a nice harsh ride out of it.
Cupping is caused by worn shocks and other suspension parts not tire pressure. I run my 37’s at 28 cold unloaded and 35 “cold” when loaded for a trip say 6300-6500 pounds including bodies. Tires warm up, I check them at a rest stop and 40 is a usual reading.Back from the dead
I just replaced my Cooper STT Pros due to annoying cupping (not severe yet).
When I first got them installed I ran them at 40 to 42psi. On a trip out west (4760 miles round trip) I increased them to 50 psi and it was teeth shattering harsh. I did some quick research on a wifi connection during the trip and lowered them to 40psi followed by 38psi and finally 36psi. At 36 psi, the ride was controlled and soft and we finishing the leg back in comfort.
Once I was back home I lowered them further to 34psi and found the tire wanted to wallow through turns. I eventually settled on 35psi. A year later at 35psi the tires are cupped, noisy, and the Cruiser is pretty frustrating to drive. I had the tires rotated and the noise and ride only got worse. I was tired of driving a tank and had Discount tire swap out the STT Pros for ST Maxx.
I have the ST Maxx set to 40psi. I confirmed with a chalk test that looks very similar to your 37's at 32. The ST Maxx seem softer than the STT Pros but it might just be tread block squirm.
Back from the dead
A lot of people in this thread seem to be way under inflated. There is a proper way to compute for the correct recommended cold tire inflation pressure.
