How do you define under inflated?
How would you compute the correct pressure?
I typically run between 30 and 36 on most my 4x4s.
I look for a balance between maintaining firm handling, and not too harsh a ride.
It varies tire to tire.
I don't use anything to compute a tire pressure and have had tires last 80k km with no adverse wear.
I'll try the chalk method. Makes a lot of sense and appears quite foolproof
LT-metric tires require a minimum of 35 psi for any vehicle, so anything lower than that is under inflated. Here's how to compute for the proper pressure according to tire pressure guru Gaijin from the 200 series forum:
"First, I'd suggest you print out a copy of the Toyo Guide to Load and Inflation Tables found here: Toyo Guide
1. Go to page 16 of the Guide and look at the info for your OEM P275/70R16. Look specifically at the Load Limit for 32psi, your stock RCTIP (Recommended Cold Tire Inflation Pressure). You will find 2,480 pounds. This is the required Load Limit for P-Metric tires on your 80 Series.
2. Since you are substituting an LT-Metric tire for a P-Metric stock tire, you need to adjust the P-Metric Load Limit by 10% to account for the different type of tire construction ion the LT-Metric tire. To do this, simply divide the stock Load Limit by 1.1: 2480 / 1.1 = 2,255 pounds. This is the required Load Limit for LT-Metric tires on your 80 Series.
3. Go to page 21 of the Guide and look at the info for tire size LT285/75R16 Single (Single simply means one tire per wheel - not a dually). Look at the Load Limits for this tire and find the first one that is >2255 pounds - you will find it at 40psi where the Load Limit is indicated as 2340 pounds.
4. Since we only need 2255 pounds of Load Limit, and 2340 pounds @40psi is too much, we need to determine a Load Limit, usually at a full psi value, somewhere between the 2340 pounds @40psi and the 2130 pounds shown for 35psi. First determine the pounds/psi between 40psi and 35psi: Load Limit @40psi (2340) - Load Limit @35psi (2130) = 210 pounds / 40-35(5) = 42pounds/psi. Now, since we know the Load Limit increases 42 pounds per psi between 35psi and 40psi for this tire, we can add 42pounds to the Load Limit @35psi (2130) until we reac a value >2255 pounds. That works out to 2130 + 3*42(126) = 2256 pounds @ 38psi.
5. So, 38psi is the Recommended Cold Tire Inflation Pressure for the LT285/75R16 tires on your 80 Series Land Cruiser.
Simple, right?
Important Notes:
1. Note that the Load/Inflation tables start @35psi for LT-Metric tires. This is because it is unsafe to operate an LT-Metric tire on road at high speeds at less than 35psi for ANY vehicle. This means that for off-road, slow speed, limited time use, it is possible to "air down" for traction; but as soon as speeds increase (generally sustained >25mph), tires should be restored to the RCTIP >35psi.
2. When determining Load INdex for LT-Metric tires, it makes no difference whether the tire is Load Rannge C, D, or E - calculations are the same. Note that this means it makes absolutely no difference what the Max Load indicated on the tire is - NO DIFFERENCE. "
