Tire balancing question
Northern New Mexico, Espanola
I just recently had some 34x10.50 r15 's mounted on stock FJ 40 wheels. The tire shop was able to balance two of the tires but not able to balance the remaining two. I was wondering if the tires were unmounted and turned 180 degrees and then remounted If this would help balance the tire? Are there any other options or suggestions?
Thanks
Vince
PS I will post pics tonight.
There are specialized machines out there that will do tire matching. You just need to call around. It's usually more expensive but it keeps the wheel weights down to a minimum.
Sometimes it can help.
I do not like to sound like I'm always negative about things but when God gave out give a shi t, bodymen, painters and tire changers held the door for everyone else. When they got to the head of the line God had run out.
Seriously, the guy has to want to do his job well. Too often these poor guys just slap em on and go. You may want to find a place that specializes in off road tires as they can require special knowledge on how to do right versus a 13" tire off a Tercel. Don't be afraid to ask for their best guy. You might get a 'you get what you get' response or it may actually be taken seriously and accommodated.
I just tell the tire store this: I'm buying 5 tires and paying you to make sure they are ALL balanced properly. If I get out on the highway and they are not balanced, I'm coming back, you will remove the tires at your expense, and I will take my business elsewhere. To date I have always had excellent luck with this approach. My local Firestone place actually tries several tires to find the ones that need the least weights. He says that most tire manufactures will take back tires that cannot be balanced properly. Granted these are for 31-33" tires not 35-40" !
Thanks guys, I am going back to the tire shop and have them put more effort into balancing these tires. The 40 does not drive that bad at 55, but it bounces a little at slower speeds (around 20 t0 25 mph).
Thanks,
Vince
Thanks
Vince
Generally you want to rotate 90 degrees, b/c you don't know were the heavy spots on the rim and tire are relative to one another.
Second, you can have the rims balanced, and even drums, and then just have to worry about the tire.
Interco tires are notorious for not balancing.
They might not even be true round.
Find a place that can shave them as well as balance.
Also look into balancing with airsoft pellets/BBs. This works well for my 38" super swampers.
This chart lists how many ounces of BB's/airsoft pellets each size/ply rating tire needs.
http://www.innovativebalancing.com/BigTirechart.htm
have them check the tires for roundness....I'm betting you have the LTB's - these are the original tire that came right after the caveman had the square tire....
take 'em back and have them make it right....swampers take some work to balance...
bk
sine80 said:
take it back and see what they can do. if you end up like me with weights stacked on weights, stacked on weights, check this out.
http://www.4x4trailhunters.com/article.php?id=18
mike
I would recommend this... I did it to my previous rig by myself. Take the wheels off the rig. Pry off the weights with a screwdriver. Break the bead with a hi-lift. Pour in the correct amount of airsoft pellets.(from the chart that cruisinGA posted) Then use a CO2 system to set teh bead again. It took me 2 hours to do all 4 tires. Would have taken less time, but the first tire took me a while to figure out what I was doing.
Afterwards the rig drove GREAT! I would even say that the tires were a little quieter on the freeway.
edit: they were 35" MTR's
Being a former tire man, I agree that a little effort goes a long way.
Our shop would always spin the tire 180 to try and get a better rim/tire balance, but it doesn't always work. I have come across tires that will not balance. Our shop would usually send them back and give the customer a new tire.
Then again, if they didn't sell you the tire, odds are they won't try very hard.
