time for a new clutch
1973 FJ40 all stock
OK, just got this Pig and its not a jeep (all I have ever had) and just wanted to confirm.
When I am in gear (1st) and have the cluth in no problems. But as I want to go forward (letting out the cluthc) The Cruiser chatters, shakes, and jumps until I get moving a bit and the cluth is being let out. Time for a new clutch?
Dan
and a resurfaced flywheel
hopefully there will be enough meat on the flywheel to get all the heat spots and cracks turned out...
I had the same problem, someone had replaced the clutch disk but never resurfaced the flywheel, just barely had enough meat left on it to resurface it.
yup. just wanted a second opinion and got a third. Anyone have a centerforce II part number for me? Or is OEM better?
Centerforce made 1 for 08/74-87 cruisers. They are 10 13/16" diameter with 10x 1-1/16" splines. Centerforce 1 p/n cf043518, dual friction p/n df518043. TO bearing part # 046. hope that helps. info is from 1999 catalog
I recognize you from the Naxja board. Small word
Dan DeCicco
This brings up a good question. If you have hot spots on your flywheel will time not eventually wear them away? I had the same problem in my previous 73 cruiser only to find upon tearing it down that the clutch was good but there were hot spots on the flywheel. Being in college at the time with no money I just put it all back together and eventually it stopped. ABout after 10k of easy driving.
I find it hard to believe that if you hot spot your flywheel that you have to take it apart to machine it. I'm sure a few of us have cooked our clutch real good to hotspot the flywheel and not have changed it.
Opinions?
If it were me I would drive it for a few hundred miles first. I would try to work the chatter out of it by intentionally slipping the clutch a little each time I start from a stop. This worked for me on my old Chevy pickup after having the disc freeze to the flywheel from sitting for years. Clutch was pretty new, certainly not worn out, and I managed to save it. YMMV
When I had very bad clutch chatter, I continued to drive it not knowing any better, and one weekend while wheeling, the clutch disk disentigrated, leaving me stranded in North Carolina.
This may have been a freak event, I don't know.
those might be the right part # for the 4 speed flywheel but is not the right p plate. the clutch disk is the same, but the p-plate and the TO bearing are different if you still have the 3 speed flywheel
I have heard (always a good place to start) that if you can idle with the rig in 4th gear, but not moving, your clutch is beyond repair. And you may have a shot of repairing it before then. Have you adjusted the clutch fork/slave cylinder, there is a little room for some adjustment.
Rezarf <><
top gear@ about 10-15mph, rpms around 1500-2000rpm....dump clutch and see what happens.
if it slips, it's time to go. if it bogs instantly you're good to go.
I have taken the chatter out of several clutches by doing exactly that. 'Cept I was told to nose my old Chevy up to a tree and slip the clutch until I could smell it. That was to avoid taking apart a "torque tube" driveline to replace the clutch.
Ed
