This little Lifter had enough?
Redwood City, CA
Trying to fix an old timing cover leak on my main thread Bumps. Got deeper into the can of worms, pulling the cam so the timing end plate/cover could be repaired and resealed. In the process of pulling the lifters, this one came out in 2 pieces with what must have been a developing crack and now looks like a perfectly new break? Don't see any scoring to speak of on the block bore but will look closer.
Can I just check/measure the cam and buy a single lifter (comparing diameter measurements to the old one) from Toyota, or do I need to buy all 12 new lifters and worry about break-in, how the cam will react to that upgrade, etc. etc.? Are there other issues I should look at? Backlash on the timing gear seems to be at .0035". Did I save anything down the road by finding this, I assume a 2 piece lifter bouncing around would not be good at any engine RPM? More detail and images on the Bumps thread. Thanks
You may have dodged a bullet on that one - looks like it stayed together until you removed it.
Looks like an opportunity to upgrade the camshaft, with new lifters of course.
Just a thought, do you know the history of the cam/lifters? If not, could the lifter be some substandard product?
Folks more knowledgeable that me recommend Delta Cams for regrinding cams and lifters; I don't know about pushrods.
They could let you know the issues involved with the cam bearings, etc.
In four decades of wrenching on Cruisers, I have never seen a broke lifter. Ever. A real fluke.
If the lobes of the cam are not pitted, I would just put another lifter in and call it a day. It’s a tractor motor.
Just a thought, do you know the history of the cam/lifters?...
As far as I can tell someone was messing around in the timing cover but did not go deeper (see other Bumps thread). I think everything under the lifter cover, etc. is all original. That means the lifter/cam has 120,000 miles and is 40+ years old.
Really like the idea of "put another lifter in and call it a day", I'll try to order one from Toyota today. Also will measure the cam (cam detail shots in the other Bump thread too).
Thanks for the feedback. Wonder what @FJ40Jim would say about the broken lifter?
Now is a perfect chance to get all new lifters and send that cam off to get reworked a little.
Not sure it's the "perfect chance" - would that not involve pulling the engine (for cam bearing replacement, etc.) and in turn finding/worrying about all the other things that should be done in the process?
When I sent my lobe worn cam to Delta for a re-grind, I asked them about cam bearings. They said if the journals looked good and I’ve been having good oil pressure, they were most likely ok.
Before that conversation I had bought a new set of lifters from ccot but Delta said send them my old ones. They re-surfaced the old and I shelved the new ones. I later found out the new ones were cheap aftermarket, and the top end was a separate pressed in cap that others had seen fail. I sliced one in half for a look and the rest became paper weights. Wonder if yours are after market.
Here's a thread on aftermarket lifters that might be of interest if you haven't seen it already. "Lifter Woes"
Jim would say he agrees with Mark A. Never seen one break like that. The bore in the block is OK, and the face looks OK also.
Throw a new/ good used lifter in the hole and move on.
Thanks Jim, nice to hear from you. Just picked up a few parts today with a replacement lifter. Sometimes these OEM parts from Toyota get me drooling. The new lifter diameter mics out 2-3 tenths over the originals.
Tenths?
From Wiki:
Tenths. In machining, where the thou is often treated as a basic unit, 0.0001 inches can be referred to as "one tenth", meaning "one tenth of a thou" or "one ten thousandth".
Edit from Gusb:
Usually a good old standard vernier micrometer will allow for breaking down a .001 inch if you can read it. Some old mics would provide an additional scale across the top of the barrel.
