- Joined
- Mar 1, 2014
- Threads
- 22
- Messages
- 150
I forgot I'm makeing a 1/4 barrel smoker to take on the trail to cook a 1-2 chicken / tri tip and if corse potatoes towards the bottom
Pictures when done, please. Sounds interesting.I forgot I'm makeing a 1/4 barrel smoker to take on the trail to cook a 1-2 chicken / tri tip and if corse potatoes towards the bottom
I couldn't wait to try out my new drum smoker, so I picked up some cheap fryer birds at Costco. I needed to use it anyway to see how it would hold temperature with different settings before I try to cook some big meat on it. Yard bird!
Just right... I like a little smoked bird..
J
Definitely a decent smoked bird, not my favorite though. The breasts came out a bit dry, does brining the birds help keep moisture? I just did those mainly to get familiar with settings on my smoker.
Also, I've seen some chatter about white smoke vs blue smoke. I read it's better to pre-heat your raw wood before throwing into the coals. Next smoke, I plan on getting my coals going in the smoker and set my raw wood on a rack and let it get hot. Does this seem like a good idea or does it need to be hotter than 300° or so?
My only suggestion, make sure you use wood charcoal and take your time. IMHO, using petroleum based charcoal (i.e. kingsford) is no better than using a gas grill and in many cases worse.
http://old.cbbqa.org/wood/Kingsford.html
No Petroleum..
I like Hardwood Charcoal as well, but it throws sparks, gets very hot and is expensive
No Petroleum..
TXLX100, brining seems to be all the rage the past couple of years...you will need to try it to see if it works for you. Having said that I, like many, went over-board and brined everything...for awhile. But I've decided, generally, I don't like the taste of the meat/fowl saturated in salt through and through and the textural changes brining can impart.
When eating out, I can taste, most of the time, whether a piece of meat/fowl has been brined. I think in the context of a restaurant where line cooks typically don't have the time to care for cooking as we do at home it gives them a wider range for timing...
