The plan
Reno, NV
Website
forum.ih8mud.com
I'm getting close to putting my 40 back together. The suspension has been keeping me awake at night. For some reason I didn't put nearly as much research into this part of things as I did others. At any rate I've been searching and reading and think I have a plan. But I would like a sanity check.
The problem is after the SOA my rig is way to high.
The first problem I identified is the addition of helper springs in the leafs.
So my plan is to
1) remove the helper springs
2) move the shackle side spring hangers in
3) remove additional leafs as required
I really don't know what to do with the front fixed spring hanger situation other than live with it.
Does this sound like it will work? I really would like a critique, good or bad.
I may be mistaken but I think that SR kit is suppossed to give you a couple inches of lift alone. Bustanutley got the right idea.
Those are long shackles. Get some shorter ones.
How much "too tall" is it?
I would put the front of the front spring on the frame as bustanutley showed, then put the top of the reverse shackle mount through the frame- eliminate the drop from the frame. For the rear, remove the helper spring, and shorten the shackle.
Good luck!
Other leaves were removed to put the Helper spring in.
stock cruiser is a 6 pack (sometimes 5 sometimes 7) I would be tempted to get a set of stock springs...
Also.. the military wrap goes on the frame end, not the shackle end..
and lose the funny Shackle reversal..
I know it is a lot of work but I would move your box anyway, level with the frame, this will make for much better steering geometry. here are some pics for reference on what my junk looks like.
you can see that my drag link and tie rod are completely parallel with each other (no bump steer. Also my box is level with the frame out of harms way.
Oh and I know that I got a freaking ps leak. Stupid thing just started leaking the other day somewhere around my cooler, need to take a gander.
I have the original springs that were removed, just need to figure out what goes where. Any help on that?
bustanutley said:
I know it is a lot of work but I would move your box anyway, level with the frame, this will make for much better steering geometry. ....
:doh: I just installed the steering box. What you say makes sense so I'll look at what it would take to move it tonight.
I'd flip the front hangers from side to side and sink the shackle end into the frame, doing it this way puts you only about .5" above stock with the steering correction kit you have .I've had one of mine like that for years it works great.I have never had any issues with the so-called rockfinders but I run 35's and flip the front springs as well .The original springs should have two different arcs , the one with less arc goes in the front .
MandMAutomotive said:
Only been here a couple of days, but it sounds like you need a hy-steer kit.
https://forum.ih8mud.com/search.php?searchid=563058
Here is some search results I found. I was told SOA needs hy-steer and PS
HTH
John
If you look at the pictures you can see my draglink, it is above the springs. That is Hysteer.
SOA can be done without converting to Hysteer but you wind up with the tie rod running at an extreme angle which causes bump steer. In addition you leaving your draglink below the axle exposed to rocks.
You don't need PS with a SOA, but SOA usually implies larger tires which definatly make PS a requirment, unless you have Popeye arms like Flexing 40. He has a SOA and runs 36" tires with no PS, welded rear and lockrite front. Don't piss him off. :D
click on my link below to see some pics of what i have done hehe
Nice work!
It looks like you used the BTB Products adaptor plate, is that correct?
That was a mistake.
I called Proffitts Cruisers, they have kit that sells for $40, includes the hangers and through frame sleeves.
They also have a way nicer Sag PS mounting bracket for $65.
The problem? Explaining to :princess: why I'm grinding off the PS plate I just bought and replacing it. :doh:
This will require much thought. I'm still open to suggestions.
