The official part number request thread
I am trying to make my own wire harness for the lift gate switch. I have obtained the bezel and the switch:
https://www.amayama.com/en/part/toyota/8493060090
and the female housing connector is 90980-11013
But have not found the right wire terminal. I thought perhaps it was this one from Sumitomo
but the distributor was not able to confirm.
Mr T. sells the individual wires for like $12 each which is silly expensive when the terminals and wire is like $1. Anyone know the part number I would need?
I have only ever seen the repair wires, but I haven’t dug super deep on this. I do believe whatever resources are available will be in the Electrical Wiring Diagram section of the FSM vs the normal parts lookup system. But if you’ve found the connector housing you’re probably already using that resource..
If you're resourceful you could find a junk Toyota harness with a similar style connector with the same pin type and de-pin it and use what you need. We keep a bunch of old harnesses around just for this purpose.
I used Sumitomo connectors from this site for my diff locker conversion. Maybe they have what you need?
Some info here
Thanks everyone. I have not dug into the FSM as I was able to get all of the parts via the online parts lookup - and a little help from my parts source.
A while ago I did find this terminal from Ballenger Motorsports:
The blade with is right width best I can tell.
I will try to dig into the FSM. Are folks downloading the FSM via the links in this MUD thread? Or is there a better source?
Need this cap. Must have fell off during a car wash. 2017 LX570.
Got this one on ebay but it didn't fit.
Question on TRD brake pads.
I have ordered the following in the past:
Front (2016+) TRD Pads - Part Number: PTR09-0C111
I have some notes on the TRD rear pads as part # PTR09-0C110 but those don't seem available anymore.
FWIW - I placed an order with Serra for the front's late last week. Now looking at my order, appears front PTR09-0C111 are no longer available either...
I received my order of TRD front brake pads today. That was a nice surprise and apparently still in production.
I have a hose with a hole in it in my evaporative emissions system leading to very small vacuum leak OBD2 code (p0456).
The vehicle is a 2016 Land Cruiser.
I am having trouble locating it in the online parts lookups.
This hose runs from the vsv purge valve bolted to the intake manifold, down to a hard line that goes to the charcoal canister. It is held on by two springy hose clamps.
Any ideas?
Any ideas?
Charlie - looks like this one:
HOSE, FUEL VAPOR FEED, NO.1​
Part number: 2382638010​
Thank you very much.
Ordered. $24.32 list. I got it locally, since even the discounted price at online parts places was more expensive once shipping was included.
So I got the black window moldings ...and now I am wondering if there are other OEM parts that are grey/black for the LX570 or LC..
anyone have any part numbers for the Lexus emblem/LX570/door handles etc (if it even exists in black)..
those giant trim pieces on the back in silver is something i want to black out.
check out this car on carmax...
I'm on the move with limited ability to search but this was covered a number of pages back in this thread.
let me start browsing this thread
EDIT: found it but unfortunately the parts I wanted are not mentioned.
You might find some overlays if they don't make stock parts.
Hi, please help with part numbers for transfer case and transmission seals, o-rings, nuts, gaskets, etc. for rear and front side, also for the o-rings for the A/C lines (not sure how many of them and what size). Thank you.
Forgot to add - 2011 Lexus LX570.
You need to be way more specific than that. It is also necessary to specify the exact vehicle you are working on.
I need to change seals on the TC and transmission on both sides (between driveshaft and transfer case, transfer case and transmission, and transmission and engine) and o-rings on the A/C lines.
90311-51008: 1
90311-51009: 1
90301-31003: 2
90311-50039: 1
90430-A0003: 2
90311-50065: 1
90179-24011: 2
90311-45032: 1
AC O-RINGS:
FRONT SYSTEM:
90069-08007: 4
90068-14011: 6
90068-14010: 4
If you need the AC o-rings for the rear system and cool box, some of them are serviced and some of them are not.
The big trim and above the lights can be easily wrapped in whatever color you want w/o taking them off. The wrap will last a lot longer than the plastything coatings and can be easily removed if you sell it or if you need to refresh it.
