I believe the correct part number is 90467-10216. 10210 is too large
Yeah maybe this Saturday if the weather holds. The Slee skids are durable but a PITA to drop in my drivewayYeah.. you need to get the skid off to have a better look.
Ah, yeah, looks like the number changed at some point. 10210 is called for on earlier rigs.I believe the correct part number is 90467-10216. 10210 is too large
check out Eskonke threadlocker. supposedly their stuff tested better than Loctite, JB weld thread locker, etc per torque test YT channel. I've reached out to CCN (all hail his name) and cannot yet post his decree.No sure if I can ask here, but for the timing cover leak repair, what loctite I can use for the bolts? The original one looks greyish. On the Toyota website I found 2 of them - Loctite 5970 and 272.
FSM doesn't call for loctite on the bolts. You're seeing RTV for the sealed interface that squeezed into the holes.No sure if I can ask here, but for the timing cover leak repair, what loctite I can use for the bolts? The original one looks greyish. On the Toyota website I found 2 of them - Loctite 5970 and 272.
No. I’d recommend getting the FSM.. the timing cover install is pretty complex, with different RTV bead sizes depending on where on the cover it is applied. Plus there are 29 bolts of 6 different kinds all with specific locations and a couple different torque values.So I do not need to use a threadlocker for the bolts? I'm confused a little bit.
Probably stupid question, but what are the FSM and RTV stand for?No. I’d recommend getting the FSM.. the timing cover install is pretty complex, with different RTV bead sizes depending on where on the cover it is applied. Plus there are 29 bolts of 6 different kinds all with specific locations and a couple different torque values.
It’ll line out exactly what is needed. Thread locker is not on that list.
Factory service manual, and RTV is silicon form-a-gasket. Technically Toyota refers to it as FIPG, form in place gasket.Probably stupid question, but what are the FSM and RTV stand for?
This.No. I’d recommend getting the FSM.. the timing cover install is pretty complex, with different RTV bead sizes depending on where on the cover it is applied. Plus there are 29 bolts of 6 different kinds all with specific locations and a couple different torque values.
Replying to myself, it appears the coolant leak is actually at the top of the engine. It’s either the oil cooler supply or return hose near the upper radiator hose. Pink, crusty, and wet down there. I think these are the right parts. Getting to it is going to be a PITFA I’m sureYeah maybe this Saturday if the weather holds. The Slee skids are durable but a PITA to drop in my driveway
| Part Number | Part Name | Price | Quantity | Total |
| 99556-20200 | Heater Hose | $8.57 | 1 | $8.57 |
| 90466-A0018 | Clamp | $3.15 | 2 | $6.30 |
2013 LC build date 07/13
Looking for, in order of importance;
Thank you!
- Front and rear differential drain plug crush washers
- Transfer case drain plug washer
- Factory service manual
- This AUDM black grille, if there's a version compatible with radar cruise that would be a bonus. View attachment 4215317
