@WanderingWarrior, your last comment made me go really deep into a rabbit hole looking for that 60% moly grease, thanks for that!
I believe that this thread is so complicated that made everyone paranoid about clunky stuff in our cruisers.
There’s MANY places where clunks can come from on this car, from drive half shafts (CVs) to bushings and driveshafts from transfer case to axles.
If we’re talking about the shafts going from the axle housing to the wheels (CV axles), then we know that there might be play in splines and repair is replacement of axle/ flange. I did it and it worked!
If bushings, then there’s a solution as well by replacing 1 or all bushings in the whole suspension and axle holding system, how deep you want to go?
I replaced all 3 front axle support points bushings, and feels like butter being squeezed on warm bread.
If inside the axle house (gears) then you know what it means, a pretty expensive job that most people don’t know how to tackle, but doable if you want your LC to keep chugging.
If we’re talking about the drive shafts (“s” as 2 of them in our rigs) usually displayed as a slight bump 1/2 a second after you reach a full stop, or a bump between the moment you release your brake pedal and reach the accelerator pedal, then we’re dealing with the slip joints in those shafts, which are splined as well, need grease to operate properly, and the type of grease needed can spark an endless debate.
(See Ford’s forums for examples).
I managed to, mostly, keep it quiet by injecting grease in there every oil change.
Took me a few tries to get old grease through the seal, but eventually it did come out and now I know it’s flowing. I use whatever grease is in the gun that day.
I cleaned the seal slide area (the shinier part that the seal moves through) with emery cloth several times until old grease came out, never used too much pressure, just enough to make it flow.
I pump a few times every oil change, some grease comes out, I’m good to move on.
I used Moly grease, same as red lithium, and yellow stuff, no matter, same results, the “clunk” lets me know that I’m due for an oil change.
Edited to add that I drove a 2021 LC back in 2021, and it Also Clunked between gears! So it isn’t a problem, it’s just how a multi-linked 4x4 system on a very heavy truck works, it has so many points of contact between your gear lever to the wheels that it’s pretty much impossible to soften them all, specially when said vehicle is 25yo!
So
@WanderingWarrior , I’m not following that rabbit today! Even though it’s an interesting chemical that I might get just to play with it a bit and form yet Another theory.
Maybe I’ll use it in an F150 to blow their minds in their really confusing forums!
