Recently purchased an 02 and went down under with a grease gun to try and alleviate the drive shaft thunk when shifting between R and D. Reading up on this forum and watching a few videos, it looked generally possible to reach all zerk fittings without lifting the truck. As a bonus, you do not need to drop the stock skid plate / splash guard that is in the way of the front shaft. All guides I've seen indicate removing that entire cover, so I'll share a few photos below on reaching it.
The engine cover has a small hatch in it that may be removed with two torx screws. I was lucky and where parked in my garage, all fittings were pointed at roughly 8 o'clock, if viewed from the rear. This is necessary to get the grease gun up to the fittings in the front through the hatch. My grease gun has a +/- 12" hose. It is easily routed through the hatch up to the fittings with enough room under to pump the grease.
Hatch in the middle is missing, two torx screws on either side to remove.
View up through the hatch to the fittings.
Clearance of grease gun with 12" hose shown through the hatch up to the fittings.
