just have the service writer put it in the notes BEFORE they do the work. to swap CVs and flanges you do not need to open up the hub per the FSM. pull the wheel, pull the grease cap, take off snap ring, unbolt/remove hub. unbolt speed sensor wire/bracket. undo the control arms. unbolt steering arm. the hub/rotor stays attached to the steering knuckle and comes off as a unit. if you want new or repacked bearings you would need to request it. bottom line, if you want something request. they will do the bare minimum about as fast as they can.
swapping flanges is very very easy. special tools needed are torque wrench and snap ring pliers. cruiser outfitters sells all the snap rings in a pack.
i just opened my front end up a couple nights ago for the first time since purchasing. removing the grease cap immediately set the tone....
not an OEM snap ring and not close to the right thickness. I have a click and a clunk. i will say that putting a new flange on backwards and twisting the axle CW and CCW showed play and the new flange slipped on like butter which is not ideal. it should be super tight with a new flange correct? i am to believe the axle is shot. im pretty sure they are original at 226k and perhaps the bearings are original as well. i am dreading having to pony up the 1500 or so for new axles and bearings but i want this thing solid and not shakey on the highway for some upcoming roadtrips. though unemployed at the moment, ill never have this kind of time again to do it so i might as well do it now, right?
In my experience I needed a rubber mallet and light taps to get the new flange over a new CV. ZERO play.
I'd post some pictures of your current CV's. They might be new, but those c-clips look like the aftermarket ones I had on my aftermarket CV's from the original owner. He had torn CV boots and a shop up-charged him for the work only 20k miles before I bought it from him. Those aftermarket CV's had nothing wrong with them and were totally fine until I added some lift - then got mild vibes. When I replaced them I did notice the factory flanges had movement on the CV's as well as the C-clip not being even close to the right gap.
My clunk is 90% gone after new CV's, and pulling my driveshafts so I could properly clean and repack the slip yolks. It was 95% gone when I used grease with moly in the slip yolks, but that stuff seemed to separate and get past the oil seal over 5k miles so I'm using a standard NGLI # 2 now and its still fine. There's the occasionally downshift and forward to reverse thump but that's just drivetrain lash and to be expected at this kind of mileage. Trans and motor mount bushings likely would take the edge off of it.
Whats interesting above is on the c-clip and hub someone took the time to mark them with a paint pen. Whats that about?
