The Official 1HD-T/FT Fuel Pump Mod Tuning Thread
After... I've read about this it seems that it can vary a lot. Anyway that's not the way I drive normally and in that case it normally runs bellow 400ºC.
After turbo it will be laggier to get the reading , but at steady pace it won't be much far, don't you recon?
I haven't put much thought into this maybe due to the afraid of something getting loose in the probe and ending in the turbo... But even so, if the reading is much correct before why the brand say to place it 10cm after turbo?
Take it from someone who purchased a vehicle with a post-turbo EGT probe who later moved it, the EGT readings you're seeing are completely useless. I was driving around making sure my Temps stayed under 1000f, then I moved the probe and drove around using the same habits and i was going over 1400f.
The turbo soaks up tons of heat from the exhaust gasses so you really can't trust those readings for anything.
I moved my probe in about 2 hours. Search the forums for methods, I drilled it with my turbo still mounted and used a magnet and a greased bit to catch the shavings. You have to punch a big hole in the heat shield for clearance, but it's a easy job.
Is you EGT probe before turbo?
If yes, 600'C is definitely safe.
After turbo, it's just a guess
Agree with what you say here.
Funny story though, had the injector pump rebuilt by one of the supposed diesel experts, based in Wagga and advertise in major magazines. After the engine was put back together by the mechanics, I went back to talk to the 'experts' about them tuning it for me. They asked if I had an EGT fitted and when I told them that I had one pre turbo, they said that they would have to install one after the turbo to tune it. Needless to say I never went back there and continued my travels around Oz.
Hi all
Great threads lots of info to process
I have 97 1hdfe, safari inter cooler other then that stock as far as I can see.
Issues having- no guts from pull off so flat actually dangerous, turbo only starts spooling from 1800 upwards.
After that pulls as good as I can imagine having 350k plus on the clock, sure there is room for improvement but at this point want to solve bottom end issue first.
Another issue is idle is at 1000 I have tried to bring it down on the idle ajust but then when I put it into gear on a hill it stalls, some setting is clearly out but being new to these cars I am not sure, maybe someone can shed some light.
All the settings on the pump at this point are unknowen may have been tweaked may not, I have not looked yet as only found this thread few days ago and I am still educating myself.
All the info is here so not really looking for it to be explained again, I have pretty much got it and will get better as I begin to work on it.
What I am looking for is some one to just give me a sequence to tackle these issues 1-5 say of where to begin, systematically working through the pump.
At least this will give me a staring point and I can go from there .
I realize that a lot of it is interconnected I well understand that from all the posts in the thread, it's just to get started and I think over time I will sort it out.
I don't have any aftermarket gauges intalled at this point I have to get onto that, as I see now as well it's hard to tune in the dark.
I also have a standard 1hdt and it is a machine off the mark I use it on the beach for my boats, good old tractor.
Trying now to get the ft to that point otherwise it is useless to me on the beach.
Cheers
Hi all
Cheers
'97 is an auto trans? Check the trans kickdown cable adjustment per the factory service manual, it's pretty common for the cable to stretch and can make the truck a complete dog to drive. Don't start making any injection pump changes until after you've got gauges (EGT and boost).
You say the engine is a 1hdfe, which isn't correct. It will be either a 1HD-FT or a 1HD-FTE, if it's the latter the injection pump is electronically controlled, and you won't be able to tune it as outlined here.
Yip my bad FT
Yes auto box has just been rebuilt so no issues there
Not about the kick down, from start it does not go even if you put it into first
Same as on a hill it's hard to even get going
I definitely think the pump is off i.e. Off boost fueling etc
The car goes well once it gets going it's just from standing
It's the same issue most guys complain about on the engines
Yip my bad FT
Check the kickdown cable 1st, one of my old trucks was dangerous to drive, boost wouldn't build until you were nearly across an intersection, downright dangerous to drive, cable adjustment made a huge difference. Doesn't just affect downshifting.
Anyone have a way to check TPS and adjust
This is an awesome truck but in present state of tune is just a dog
Need to figure out the isssue otherwise it is useless as a beach vehicle
Am out the country at present so will tackle it as soon as home
Just getting all ideas and info together now
I have mine set to about 0.8V when the throttle is wide open.
It works out to be about 3.4V closed but I set it to the open figure.
Adding it from this thread: DEV - Injection Pump Tuning Guide
Start Tuning
1. Find max boost target - The maximum fuel volume the injector pump and injectors can deliver may limit the maximum boost level target. To find this boost target ensure that the follower pin will travel to its maximum extension of the aneroid taper used and not travel up the over boost portion on the taper. For this step, I plan to remove the spring from beneath the diaphragm and add spacers between the pump body and the bottom of the diaphragm to limit the aneroid travel into the pump to ensure the follower pin cannot ride up the over boost taper. The aneroid taper used and spring tension is not critical at this point as long as the follower pin reaches its maximum extension as we are only finding the max boost target. The no boost and spooling fuel levels may be richer than desired at full throttle but we can control that with our foot for now. Set the boost controller to the desired boost level and set the maximum fuel screw position to a full boost, full load AFR (22:1). If the AFR target cannot be achieved and is lean, (>22:1) the injection pump/injector combo may not be able to deliver the fuel required so while leaving the max fuel screw at the maximum position, begin winding the boost back until the full boost, full load AFR is at the desired position. This boost level becomes the maximum boost target.
2. Find the boost level required to transition from spooling fuel levels to full fuel level - Once step 1 is achieved, slowly wind the boost back without touching the max fuel screw until your spooling fuel AFR (18:1) is reached. This becomes the boost level where the aneroid should stop traveling into the pump and therefore the boost level where the follower pin stops extending out of the pump. After the turbo reaches this boost level, the fueling per psi should remain the same and the extra boost is used to lean the AFRs to full boost, full load levels (22:1).
Note - Another option for tuning is to have a flat section on the aneroid taper at the max fuel position and allow the aneroid to continue traveling into the pump without the follower pin extending any further out of the pump. I see a few negatives to this method: 1. The max spooling rpm still has to be found and the flat section will have to be ground to this point. 2. This method effectively reduces the taper vs. boost resolution as the same taper distance is now used for a greater boost value. 3. Because of 2. the spring preload will have to be increased meaning there will be more boost required before the taper will begin to travel into the pump which reduces the no to low boost tuning ability of the compensator. Due to these reasons I will pursue the first method and ignore the second from here on.
3. Find the maximum depth of the aneroid taper grind required to lean out the no boost fuel level- If after the max fuel is set in step 1, reinstall the spring beneath the diaphragm and test the no boost full throttle fuel level AFR. If this is found to be too lean (I'm plan to aim for <14:1 >16:1 with a performance turbo) ensure the spring seat star wheel is adjusted high enough that the start position of the aneroid is dictated by the smoke screw cam and then adjust the smoke screw to force the aneroid start position to deeper into the pump. This means the follower pin starts on the aneroid taper and not on the outer diameter of the aneroid. If the no boost fuel AFR is too rich adjust the smoke screw to allow the follower pin to ride higher toward the maximum aneroid taper diameter. I would like to keep the smoke screw adjustment if possible at this point. This may be a futile effort and may not be possible or required in the end, and I may have to grind the top of the aneroid and the profile from the smoke screw cam but I will cross that bridge if I find the no boost fuel is still too rich and the follower pin is still not riding on the aneroid outer diameter. To allow the aneroid to extend further up out of the pump I plan to insert a thick gasket under the top diaphragm cap. If after allowing the follower pin to start on the outer diameter of the aneroid the no boost fuel is still too rich, to increase the difference in the no boost fuel delivery to full boost fuel delivery the follower pin has to travel further from one (no boost) to the other (full boost). As we now have the follower pin starting at the aneroid maximum diameter the only change we can make now is to grind a deeper depth on the taper and set the full boost fuel again. I remember reading somewhere that the pin follower only extends so far out of the pump (6.2mm or 6.5mm I will have to confirm) so a grind any deeper than this is useless. To find the maximum distance the aneroid can travel into the pump I plan to use the follower pin to measure the distance that the aneroid can travel by removing the diaphragm from the aneroid and adding a spacer between the bottom of the diaphragm and the top of the pin to allow maximum travel before the diaphragm bottoms out on the pump body and rotating the aneroid once it is at max depth. The follower pin will then mark the end point for the maximum aneroid taper. Once this measurement is known I will then grind a deeper section of taper to this section and set up the full fuel to this point as per set 1. From my reading I expect that even when the follower pin rides from the outer aneroid diameter to the maximum aneroid taper depth, the no boost fuel may still be richer than desired. The is nothing else we can do about this without pump modifications.
4. Find the spring preload required to allow the aneroid to travel the correct distance into the pump - The spring preload (the force already applied to the spring when the aneroid is at its starting position) and or spring free length (height of the uncompressed spring can be made longer by adding spacers) are the only adjustments we can make to this setup as the spring rate (distance the spring will compress as more pressure is applied) is set and short of replacing the spring there is nothing we can do about this. This means that we can only really adjust the preload (force required to be applied by the diaphragm before the aneroid will begin to move down into the pump) to limit how far the aneroid will travel into the pump at the desired pressure. This can be done by making a controlled pressure test rig to simulate boost pressure onto the top of the diaphragm. Start by removing the aneroid from the pump and the coloring the taper where the follower pin will ride with a permanent marker and then reinstalling the aneroid. At this point you simulate the maximum spooling boost level found in step 2 (not full boost) a few times with the test rig. This will show where the follower pin is riding on the aneroid taper. The spring seat star wheel will need to be adjusted up or down to allow the follower pin to ride along the whole taper. It is best to test that the follower is not traveling the whole taper to early by performing the same test with a slightly lower pressure and ensuring the follower pin does not travel the whole way up the taper. Ideally a new stiffer spring will provide the best solution here but I will proceed with the stock spring for now. Due to the stock spring being a bit soft, this setup is going to be a compromise between spring preload and aneroid travel. As the aneroid travel is more important this will be the deciding factor for me.
5. Customize aneroid taper profile for best turbo response - Now that the maximum boost is set, the maximum fuel is set, the no boost maximum fuel is set and the aneroid travel is optimized to the maximum spooling boost level, we can begin customizing the aneroid taper to provide the optimal fueling levels to assist in making the turbo as responsive as possible. My intended method to achieve this will be a slow process but I intend to find the best taper possible for my turbo. My plan is to lower the boost controller pressure one psi at a time and grind the taper to suit maximum spooling AFR. For example if my maximum spooling pressure found in step 2 is 25spi (@18:1 AFR), reduce the boost controller to supply 24psi and drive to full load, full boost and note the AFR. If the AFR at this point is leaner than my spooling AFR of 18:1 I will grind a little bit from the taper at the 24spi mark and test again until the AFR at 24psi is at 18:1. Once this is right I will reduce the boost controller to 23psi and repeat the process again. Once I have reached a point that the boost controller is not controlling the boost at all because the delivered pressure is purely controlled by waste gate spring tension alone, I will try my best to load up the turbo at low rpm and note the AFR and boost pressure and grind from there. This will not be as accurate as the previous method but I cannot think of a another way to do this. I plan on watching the AFR and boost levels and slowly grind from the higher boost portion until I see the AFR reaching the spooling set point. Depending on the no to low boost turbo response, the no boost AFRs and the boost pressure required to overcome the spring preload I expect to maintain slightly higher AFRs until the turbo is delivering a few psi of boost.
The other factor here that is unknown to me at this stage is the possible benefits to running a slightly deeper grind on the taper for spooling (resulting in a richer AFR than the setup described above) as the turbo may be able to build boost faster than the compensator can adjust for the extra boost. The benefit of this may be an even more responsive turbo still without a sooty exhaust. I will cross this bridge after I have finished all the steps above.
Start Tuning
Great write up. This seems like a really sound methodology for tuning at high boost levels.
What do you think about the over boost taper? Is there any benefit to retaining that functionality?
Seems like a progressive rate spring would be a good idea for these pumps.
I wonder how hard it would be to data log from your boost gauge and AFR, if you could see on a graph what your AFR's are at any given boost level it would really make grinding your profile a snap.
I also think if it were me, I'd get out my engraver and mark the aneroid depth in 5 psi increments once I get the spring tension dialed in. Maybe nail Polish so it's not permanent.
Thanks @DancesWithMutts
I don't see any benefit to retaining any over-boost functionality. Mainly for the same reasons as using a large flat spot on the deep section of the taper - It sacrifices anreoid travel and therefore makes the useful taper shorter.
I had not thought about a progressive rate spring, It's a good Idea. I will have to see what the taper looks like in the end to see whether that would be beneficial or just a slightly stiffer spring.
I'm sure the Innovate MTX-L has some logging capabilities. I have not tried it to be honest. I would need a digital boost gauge with logging as well which I don't have.
I like the idea of marking the aneroid in increments. I think I will probably do something like this.
One other thing to note. I don't think this tuning procedure is limited to just higher boost levels. It could easily be adapted to lower or stock boost levels with a few minor tweaks. This was my plan originally though I have been too busy and while my new turbo is not here until he end of the month, I will want to put it on asap and don't have the time to test this procedure with the stock setup.
To adapt this to lower boost levels, you would start with a boost target confident that the pump can deliver enough fuel.
This may mean that it is not necessary to have the pin follower starting on the outer diameter of the aneroid to provide enough difference for no boost to full boost fuel.
Due to the set spring tension you may not be using the entire aneroid travel and therefore may wish to keep a flat section or the over boost ramp.
You might be happy enough with an aneroid taper that is already installed on the aneroid. I'm pretty happy with mine at the moment.
The rest I think would be basically the same.
