- Thread starter
- #261
Brand new. I have also considered the water pump as well as a clogged jacket - that would suck, or a bad sending unit.Condition of the radiator? If used, have you had it serviced?
Thanks Yoop. I was just at Home Depot the other day and I saw one sitting there on sale and considered buying it just for that purpose.Do you have an infrared thermometer? You could take some temp readings of the block and radiator when it looks like it's overheated. If they are way lower, then maybe the sending unit is bad, or the gauge.
I noticed that in the heat of the summer the temp would increase as I drove but decrease when I idled. Almost as though the thermostat got hot enough to open and allow circulation at idle but cooled enough while running that it would close and the temp would rise. Does that sound possible?
What I was thinking was the the engine would get hotter at idle and the thermostat would open. While driving it would cool down enough and cause it to close sending the temp up. Now that the ambient temp her has fallen below 95 degrees everyday, the temp is not getting high enough to open the thermostat. That was my line of thinking anyway.
If i get an infrared thermometer, what temperature range should I be looking at and at what locations?
In hopes of the simplest solution I just checked, the fan in on in the correct direction.
I am going to purchase a thermometer at HD tomorrow.
I will search for an operating temp this evening.
I have the 190 installed. The other one is 180.what's the thermostat rating?
Ideal temp is generally around 190°F. I think hot on the gauge is about 230°F. So if the gauge says hot and your thermometer says 188°F then the gauge or sender are bad.![]()
The other thing I just realized is there are three different sending units. '68 - 9/72, 9/72-10/79 and 10/79-8/92. The gauges are from late '72, the engine is a 2F and I have no idea what the sending unit came out of. I do not know if the the difference is in the thread pattern on the sending unit or if there is anything different about the ohms at which they function. If they were not properly matched that could be an issue but I would think they would all work under the same resistance.
Yeah. I was just flooding my head with tech and that obviously makes sense. Anything a little over 190 and it opens. Duh.
So you're desired operating range is basically 190-200 I think.
Yeah. I was just flooding my head with tech and that obviously makes sense. Anything a little over 190 and it opens. Duh.![]()
It would be pretty sweet if it was just the sender.
