Hey, that's the helmet I'm trying to get at Harbor Freight except they have a lot of missing inventory and can't find them. You like it?
1 and 2, Rear diff installed from both sides. Sorry for the low quality, I am using my crappy camera in the garage. You can see a little bit of the upper control arm in #1, with the adjuster welded in.
3, My powder coated wheels with the tires mounted and balanced. The powder coating was a little glossier than I wanted, but oh well, they look good.
Jack: Are you going to lengthen the rear sway bar connecting rods? FYI: I lengthened mine 60mm and it has worked out very well...
Those control arms came out AWESOME Jack!
Nice work!
I like the rim and tire set too!
I may have missed it, but are those the stock rims that you had powder coated?
Its looking awersome!
Another ?... Is there any thing that needs to be done with the pinion angles with the lift, or is there going to be enough flexability in the u joints to account for extreme angles?
Do they make shims for that?
I realize the rig is still up on stands, but the pinion flange on the diff looks to be pretty vertical.
Just curious.
BTW, I picked up a HF auto dark helmet...I got flash burn welding the body panels, but havent had a problem with welding the bumper...
Go figure! Maybe it was the setting...
K
That's some sexy shiat!
Jack,
MY Slee front springs came into contact with the leading edge of the bump stop lip after the caster plates were installed. So, check out that clearance if it's around 1/4" or so, then grind down the lip. Also, can you use the bathroom scale to come up with the total tire+rim weight?
Here's a pic
Spring rubbage
Later.
Nice work!
Just curious.
K
Does yours have the pirate skull on the side? It's supposedly pretty fast at 0.5ms, some of the others were slower.
I think the lack of a helmet was my last excuse to not be out practicing with my new welder, if I'm missing any other safety equipment I'll probably notice pretty quick.
Jack, can't wait to see it on the trail.
Great, just what I needed, more things to do.
Jack
, so Saturday morning, we drove down to Gearman's shop in Sacramento. I was expecting to drop it off and have to either ship it back or drive back down and pick it up. Sean (Gearman) dropped what he was doing and went to work. Several days of frustration for me and he was done in less than an hour. I was in and out in about an hour and half.
Last two.
AYE!
Congrats Jack!
So whats happeining then with the front locker?
Is it something that is a real WRENCH in the works?
What else needs to be done till its wheelable?
Looks friggin awesome!
Nice JOB!
K
