- Thread starter
- #381
Last weekend my power steering pump went out on me and sprayed its fluid everywhere. After a few emails and a phone call, I drove to Stockton Friday night after work to pick up a used pump and a rebuild kit from Georg @ValleyHybrids (Orangefj45). I ended up driving out since I'm trying to have it fixed before a fishing trip next weekend and if I waited for shipping I wouldn't have time during the week to finish it. I got to his place to pick up the parts around 10pm; situations like that are exactly why I always try to buy parts through him.
I spent most of the day trying to remove the power steering pump that was in my truck, then cleaned both pumps up, checked the shafts movement to see which pump was in better shape ("new" pump turned smoother and more quietly), and started to tear them down. I'm going to use the reservoir from my old pump since its in better shape.
I had a hell of a time getting the pump out of the truck this afternoon.
The first issue I had was to simply get the pulley off. The best way to do it was to make the belt extra tight, then push down on it while going at it with a wrench in the other hand. (I didn't know this at first, but a quick call to Georg and it was off on the first try. Thanks again dude!)
The next issue was getting the pump off the engine. There are 3 bolts that hold the pump to its bracket; two on the front behind the pulley, and one on the back of the pump. The two on the front are easy to remove, but the one at the back has very little room between it and the exhaust manifold. Most people have issues with removing the bolt after loosening it, but I couldn't even break the bolt loose. I rounded a few of the corners trying. (ended up needing a 3.5' jack handle on the wrench to get it off at the workbench!
) The bolt I replace that one with will be cut slightly shorter so that it can squeeze past the exhaust manifold.
Untitled by Darrell Vaughn, on Flickr
So the next option is to remove the bracket that holds the pump to the block. With all the smog crap right there, its not exactly a fun thing to do. The number of combinations of extensions, elbows and special wrench attachments I tried to get to the bolts is off the charts. Eventually I got it off, but not after several curse words and a few trips to the parts store for a couple of new wrenches.
I let the replacement pump soak in some degreaser overnight so it would be a little bit easier to work on.
I got the reservoir taken off my old pump, then tore down the replacement pump. I had to stop when I got to the snapring on the flow control valve since I don't have a set of snapring pliers. (tomorrow I will. lol) From that point I just cleaned up the parts, preparing them for paint in the morning.
The internal parts are all bagged and tagged, ready for a quick cleaning and reassembly.
...meanwhile the workbench looks like s***.
More to come tomorrow.
Untitled by Darrell Vaughn, on FlickrSo the next option is to remove the bracket that holds the pump to the block. With all the smog crap right there, its not exactly a fun thing to do. The number of combinations of extensions, elbows and special wrench attachments I tried to get to the bolts is off the charts. Eventually I got it off, but not after several curse words and a few trips to the parts store for a couple of new wrenches.
Untitled by Darrell Vaughn, on FlickrI let the replacement pump soak in some degreaser overnight so it would be a little bit easier to work on.
Untitled by Darrell Vaughn, on FlickrI got the reservoir taken off my old pump, then tore down the replacement pump. I had to stop when I got to the snapring on the flow control valve since I don't have a set of snapring pliers. (tomorrow I will. lol) From that point I just cleaned up the parts, preparing them for paint in the morning.
Untitled by Darrell Vaughn, on FlickrThe internal parts are all bagged and tagged, ready for a quick cleaning and reassembly.
Untitled by Darrell Vaughn, on Flickr...meanwhile the workbench looks like s***.
Untitled
20140607_152524
20140607_184137
20140607_202106
20140607_202222
20140607_202238
20140607_234353
20140608_202118
20140608_011115
20140608_202136
20140608_202158
20140608_224423
20140527_152114
20140608_225007
20140608_224238
20140608_224307
20140617_020245
20140621_172516
20140621_191625
20140621_191747
20140622_003242
20140622_003441
20140622_003348
20140622_003411
20140706_170023
20140706_165915
20140706_172003
) Once that was done I replaced the bushings with poly ones from SOR and went ahead and bolted the bar back up and adjusted the links to the proper height.
20140705_164551
20140705_211614
20140705_122512
20140622_152912
20140706_205350
