That is not accurate.
We talked about WBs a while back and with everything things change. At that time innovate was probably the best choice and even that didn't have the range you say this one has.
Whats the thing on the toip of your air can?
Did you guys get the belt thing figured out?
Glad your up and running.
sounds sweet would love to see some dyno numbers. 4 wheel dyno's a hard to find. thinking about SC ing as well. you HAVE to run premium correct. I know if you put that much money in it why would you run anything less but ouch premium is as much are near the price of diesel. :-<
Welcome to the Robbie-built-Toyota-blown Club!
Nick
Also curious about Robbie's impression of this gasket. Aside from the ability to adjust compression, does he think it would it be a good gasket for a stock motor?
So what prompted the realization that you were running lean and needed more fuel?
which it's your AFR at full boost . ? there any temp issue yet .?
ditto/ why the change in fmu?
I'd look into an intercooler to help with that verses water meth injection unless of course a WB showed it was still a fueling issue.
As usual, your right on. The shop that is providing the water/met injector is going to look at an air to water intercooler also. I was going to keep that a surprise but oh well. The shop is Infinite Velocity Motorsports in Sparks. They build a lot of motors for D. Trent of Trent Fabrication fame.
