After eight months of being down (Due to many different factors that have been posted elsewhere) the motor rebuild has started.
The details of the build; First and foremost, I am not assembling this. Robbie aka PowderPig is doing the work and I am merely trying to avoid getting in his way.
The block was bored over 1.25mm and decked five thousandths. I had JE piston make custom pistons and rings.
I'm using ARP Head Studs in place of the factory head bolts (ARP part number 203-4205 Toyota Supra 2jza80).
A picture of the Cometic Multi-Layer Steel Head gasket (I apologize, I can't find the Cometic part number, but when I do I will update). Visible under the HG is blue Hylomar Gasket dressing.
The head received a complete work over. The head was decked two thousandths, ported, polished and seats cut.
A couple of coats of paint to start with. The block is flat now, but will get re shot in a semi or gloss because we didn't like the paint we used. The old water pump is pictured, however a new one is on it's way.
