sum-ting-wong...
Gulf Coast
ok, anyone who has ever read a post from me knows I wasn't blessed with any technical or mechanical prowess so please forgive the explanation here, but...
Driving home tonight I noticed the cruiser ('97 w/265k) got SIGNIFICANLTLY louder in the cabin while traveling @70 on cruise control. It sounded like I was sitting in the wing seat of a DC-9 after takeoff. I also noticed a good deal more vibration from under the D&P front seats.
If I accelerated it got worse, and the opposite when I slowed down. No warning lights, oil pressure & temp were fine. Steering wheel was rock solid.
Could be a number of causes, but I would start by testing the u-joints on your drive shaft. What suspension do you have?
To rest your u-joints pull you front drive shaft off, check for and binding in both joints, then lock your center diff and go for a drive with just the rear shaft in. If the noise and vibes go away, then you know it's your front shaft. If it's still there, then put the front back on and pull the rear, and follow the same procedure.
Grease your slip yokes on the driveshafts and your u-joints. Then look under the dash where the steering column goes through the firewall and see if the rubber seal around the shaft is torn out.
I tink you have an exhaust leak too.
Btw how do you know sum ting wong? I know him long time, he nice guy.
he normally travels with his cousin how loong and a nephew called how suun.
The pronunciation of the third pilot is wrong in the report. Did a legitimate news org actually report this!!??
Check for exhaust leak(s) at manifold to Y pipe, Y pipe where it merged into one pipe, all flanges, resonator and muffler. Y pipe is a common failure point
True story, but what makes it funnier is it happened to a local San Francisco station, the most liberal and PC city in the country. Unfortunately, the NTSB intern was fired, probably the first time in history a gov't worker was fired.
I agree with Mryanangel, it sounds like a bad u-joint. Crawl under and feel if there is any play.
True, but a bad exhaust mount would. But this is purely going off of OP's description, u joint should not be that loud.
True a bad exhaust mount would vibrate, but it would likely also be rattling.
It was the u-joints in my front drive shaft. I had both shafts pulled and replaced all 4 just to be on the safe side.
Thank you to everyone who tried to help and to myryanangle for hitting it out of the park on the first reply.
Cheers!
Glad to hear you got it sorted out, did you install new OEM joints?
Nice work mate. Those toyota u-joints are very high quality, they may very well be the originals that you pulled out, will be a long time before you need to touch them again.
