suggestion for shims
Most vendors recommend 4 degree front shims with 1.5 inch longer shackles.
Your best bet would be to get a front end alignment and ask for a caster measurement. Take the difference in your caster measurement and Toyota specs and that's the shim needed. Can anyone confirm this??
I went with the 4 degree, but until I replace the TREs and get it aligned, I won't know if I got it right.
Did you get the Hell Creek Lift?
Good luck
shims you can get any where,
check your local auto parts store.
some giant clamps will hold them together
Where do you guys like to get your shims?
Where do you get longer spring pins?
What do you use to hold spring pack together when changing spring pin?
Not sure on the longer pin, but if you get steel shims, they can be welded to the perches and then no longer pin is needed.
Regarding holding it together-don't sweat it. Two "C" clamps one ahead and one behind the pin will do it.
If you do end up going with new spring pins, you may need to drill the hole in the spring itself. That takes a carbide bit, and thanks to a tip from PinHead and recent extensive personal experience, a masonry bit will work, and is far cheaper than specialized hard metal drill bits. It is also easier to disassemble the spring pack and drill one leaf at a time.
Source for shims-Roger Brown will make you any angle, and width you want in steel. Very nice guy when I called him last year. This is his website: http://www.4crawler.com/
Yep, went with the Hell Creek, after talking to Tom down there I couldnt see where I could go wrong. I finished bolting up the lift, and puttin on the shackles, If I can get it to work ill post a pick in a little bit. I was impressed with the lift, it looks like good quality stuff. I dont think ill regret it at all, I appreciate all the help and your pics and opinion. I owe you one.
