Steering Woes
Western Slope, CO
I now have sag. power steering on my 40. I used the Napa ATSCO 6529 part #
Which seems to be more like a 4 turn box. So it's great up to about 40 mph or so, anything above that and it seems way to fast. I would not consider driving it on the street the way it is now.
I'm running a drop pitman arm off a Cherokee, may be like 5-6” long. I have also done the WTOR ps pump mod. Which should only affect the steering at idle right? So aside from another gear box what could I do to make this thing more streetable? What about a steering stabilizer?
Before you installed the box did you test how many turns you could get out of the box? Post install how many turns of your steering wheel do you have lock to lock now?
I have the 27-6529 part number from napa and my box is definitely a 4.5 turn box, first thing I checked before leaving the counter.
doesnt sound lik a 4 turn box if its that scary to drive, double check
I will check it out tonight, this should be number of turns lock to lock? Also another problem I am having is not the hitting the steering stops turning in either direction.
Yes, Your wheel should turn 4.5 turns lock to lock.
you can adjust your stops, but i had a similar problem when i turned left, i would turn all the way right but not all the way left
Yeah The stops are adjusted out as far as I can without them falling out. That's what makes me wonder if it is a 4.5 box.
Ok I do have a 4 1/4 turn box....:D
However I'm wondering if my problem with the scary fast steering is the castor?
I bought this axle with soa done, don't think it was turned though. My driveline angle is ok, using the small downey flange to the 700r.
I know that I should do the cut & turn, but don't have time before Moab.....
So can I use shims for now to make it more highway friendly??
If castor is the issue adding shims will correct the scary steering problem. When I had bad caster it was noticable at most any speed as the truck would follow any rut in the road like it was on railroad tracks and the steering felt very vauge and darty. Does that sound like your steering?
Have you ever measured your caster with an angle finder to find out how much you have? If you look at your front pinion is it tilted up at all or level with the ground? Are you running stock length shackles in the front? If the pinion is pointed up towards the tranfercase and no cut and turn was done you found your problem.
Thanks John, that describes my steering exactly....
driveline angle is 16* measured on top of diff 14* is there a standard?
Looking at my steering arms too, looks like they are pointed down some.
So to increase my turning radius finding a longer pitman arm will cure it?
shackles are 1" over stock I think anti-inversion. The pinion does look to be pointed up some.
Longer ptman would make it worse. Longer arm means more faster turning.
I know it is a temp fix, but maybe a steering dampener is the easy short term fix? Probably won't help with the wander, but it might firm up the dartiness?
It seems to me that these problems are typically a combination of a couple things rather than one big one. Make sure everything is snug and in good condition. Check everything before you dig in.
Yep, it sounds like your issue is caster. I would start with a 4 degree caster shim. Someone on here posted that Napa carries castor shims which are not aluminum (bad). I ran a set of aluminum and sure enough they crushed and allowed my ubolts to become loose, kinda scary. If all you can find is aluminum in your area you can order custom shims online made from steel.
One source is www.4crawler.com who is a wealth of information.
SO are you saying your axle housing is Pointed up 14 degrees? If so your pinion should be pointing straight at your t case or close to it.
A couple of things.
If your not hitting your steering stops you have two problems
1. you need a longer pitman arm
2. By not having your steering stops adjusted right you take the chance of snapping a steering arm or breaking your steering box (it is now acting as your steering stops). I have this problem and until I get the new pitman arm installed I am just a little more carefull with turning at full lock.
But first before doing anything with pitman arm get your castor correct. Stock is -1. With 33" tires and higher you want -4 to -6 castor. That means your steering arms will point more up.
I got some 4* shims on and just did a road test.....what a difference it made.
Found out that I have another issue now, my pitman arm has too much drop and is hitting the spring pack when turning left with the tire stuffed.
So this application for this gear box is for a J$$p truck? can I use that pitman arm also?
The one I have now is from a cherokee and has like a 4" drop
Caster is a nice thing to have, isn't it. :) The beauty of the Saginaw box is that you have a wide range of pitman arm choices with many different lengths and drop. There are Mud vendors who probably carry a arm with less drop or you could try any heep supplier or 4x4 vendor. Your other option is to lower your bumpstop to keep the arm away from the spring but you will lose uptravel.
