steering/handling issues
St Anthony, ID
i traded my 60 for a 40 and have a few q's regarding what might be going on with some stuff on my new 40.
some info on the cruiser- it's soa, cut and turn, originally drums up front. jto disc conversion. no power steering. running 35x12.50 mtr's.
the issue is that when i exceed about 45 mph, the cruiser is all over the road. it seems like any little bump or rut in the pavement carries the thing and it goes fast. it is actually pretty scary to drive it any faster than that, which sucks.
surely others have had similar issues and they can be resolved. what could be wrong? where should i start looking?
thanks guys.
Two thoughts. First, the thing that bothers me the MOST about the drum spindle-bolt on disc kit is the increased probability that the installer used the 'opportunity' to avoid replacing/rebuilding the knuckles with new bearings.:eek: If the nuts on the steering knuckles are coated with old dirt, you know where to start!:rolleyes:
Second thought. Have someone turn the steering wheel for you while you check for lateral rocking in the steering center arm.
Good luck.;)
Mark A.
Does it have shackle reversal? With SOA it should.
Does it have extend shackles on the front spirngs? If it does, buy an angle finder from Lowes, or just about any hardware store and check the caster on the front axle. Your problem sounds like too much negative caster.
Also, probably due to old tie rod ends and rag joint. I replaced these and my steering got fixed. Also make sure that your ubolts up front are tightened.
ill check all of these things. i forgot to mention that the front drive shaft is not currently on the vehicle so i don't think it is the too much caster thing.
65swb45-what do you mean check for lateral rocking in the steering arm? please explain. thanks.
Symptoms suggest that your caster is off - large tires greatly amplify the wandering effect induced by insufficient camber. Factory spec is only 1 degree - some folks like more. More caster means better tracking at the expense of steering effort and increased tire wear. Negative caster eliminates your tires' tendancy to track straight.
From the 1980 FSM:
Recent threads have extensively discussed this issue. Searches on "camber", "shims", and "wander" should provide lots of info.
HTH, Blake
When the drag link moves forward and back, the center arm is supposed to rotate cleanly and immediately move the relay rod from side to side. If the center arm rocks back and forth before it begins to move the relay rod, then you are no longer in control of your vehicle; YOU ARE REACTING TO IT!
Hth
Mark A.
ive been having this problem..
i couldnt go faster than 40km/h
i tightened my pitman arm n had less wobbles n could go about 60 i think..
now i got shims for my castor and currently waiting for my new center arm:D ..
From the 1980 FSM:
HTH, Blake
This is a great pic:confused: 1 degree +/- 45'?? Then almost 0 degrees and almost 2 degrees would be fine?
I just went through this with my forty. After a couple of years with death wobble on my 73 fj40, I could not get it to stop wobbling. Tried everything. Then the last thread about the caster angle made me go out and check mine. Wow! I was at +10 degrees:eek: Got some 4 degree shims, even though still 6+, it drives completly different now. A big improvement. No death wobble and handles bumps in road fine. Now, if I can get the ARB installed by wednesday for the Rubithon, I will be happy. :bounce:
update-
i took some pics this morning and the steering is different than i thought. although there is no power steering pump, the column goes into a box and runs things from there. i don't know if that is set up right since i have never converted anything to power steering. Here is a pic:
also, it appears from comparing the diagram to my castor, that i have negative castor. with the ubolts flipped for the soa, the points of the U point forward. that is negative castor right? it wouldn't be reverse due to the soa? if i have negative, will the shims fix that? thanks again everyone.
saint60 said:
update-
i it appears from comparing the diagram to my castor, that i have negative castor. with the ubolts flipped for the soa, the points of the U point forward. that is negative castor right? it wouldn't be reverse due to the soa? if i have negative, will the shims fix that? .
It would depend on how the perches were welded and whether the knuckles were cut and turned as part of the SOA.
Best thing to do would be to measure the caster angle using a magnetic angle from the flat on top of the knuckle where the arms bolt on. If you put a straight edge on the flat, you can read the angle with a magnetic angle finder. Be sure to do this when the cruiser is parked with the wheels straight ahead on a level, flat spot or subtract the angle of the parking surface. Shims can be used to correct the caster up to 6 degrees.
Also check for wear on any of the steering components. Have someone turn the steering wheel back and forth while you watch. Anything other than the wheels turning and the linkage moving straight back and forth needs to be repaired or replaced. Look for inappropriate movement at the knuckles, tie rod ends, spring bushings and the spring perches.
ok-
im not understanding how to measure the degree of the caster. the knuckles were cut and turned. i'm goofed up on how do you tell if it is negative or positive caster since the ubolts are flipped. is it the same? should the points of the U be pointing toward the back? they are obviously (seen with the naked eye) pointing toward the front and the spring perch is tilting toward the front. that seems opposite of what the diagram that was posted indicates. am i correct?
where can i get a magnetic angle finder and how do i do it? do i check it with the tire off with the perch compared to the top of the knuckle or what?
thanks.
I know that caster angle can cause your problum, but have you tried to rotate the tires or have them balanced? If your wheel balance is off it will have the same result as caster being off. I just fixed my "death wobble" at 40 mph and it was simply the tires being out of balance..... Just a thought
Go to lowes or home depot and get an "Angle Finder". It is like a drawing protractor with a needle that always points at '0', $10 Here is a pic
Take Pin-head's guide and place a stright edge next to where the nuckle arms attach to the knuckels. Place the angle find on top of that and read the angle.
Hey, I just noticed my red star is gone? Good grief! I forgot to renew my star! What a moron. Sorry guys, don't want to appear like I don't support this great board. I will be more attentive in the future.
saint60 said:
ok-
thanks.
Read what caster is first:
http://www.familycar.com/Alignment.htm
The U bolts don't have anything to do with caster.
You need to measure the caster angle with the wheel on.
A wheel alignment shop canif necessary. measure the caster and adjust it
Need pics of the pinion angle. It's a SOA but but is it really Cut and turned?
My guess is it needs more caster. But that cannot be confirmed until you take an angle finder to the knuckle.
