I ordered the kit from Cruiser Corps and used instructions in the FAQ here and it leaked worse, I reopened the box and it looks like I sheared an o-ring when I put it back together. I am sending it to WTO to have it done right.
No need to order a kit if sending to San Angelo. They supply their own. If you sheared an O-ring I believe you can order those separately from Toyota. I may be wrong but it’s worth a shot if you have it apart. Good luck. Wish I was closer as I’d give you a hand. Jimmy
... if you did it the first time, had a problem, took it apart to identify the problem, identified the problem, you seriously can’t buy an Oring and put it back together one more time and be done?
Matt, are the o-rings available separately. I’ve done a handful of these boxes and would not hesitate to replace a bad one if I had access to it. Buying an aftermarket kit could be another option and you can pluck the needed O-ring. Would be a lot cheaper than the round trip to WTOR.
you'll have much more satisfaction having fixed it yourself rather then paying someone else to fix your mistake.
I didn’t quite overcome it but I had no issue w/ install. Somehow I just did it. Later while on FaceTime w/ Jim @CenTXFJ60 and Ryan, @CaptClose during their assembly maybe six-twelve months later, they figured out a trick. Jim wrote it somewhere here or maybe he can rewrite it... apologies that I can’t recall. That was my first ever rebuild of anything back in May ‘16. Seems so long ago esp now w/ the s*** heightened roller coaster ride stay 6 ****ing feet from me life, we have happening now.That O-ring you most likely sheared / tore is available separately from Toyota, should you need it. I think the one from Toyota is Teflon coated? Read the FSM on it, as there's a SST that helps the install but others have done it being careful...
@NeverGiveUpYota I think had this issue ? She overcame it, but she's a badass.![]()
