Stainless Steel Windshield/Doors/Hood/Amby FJ40 Hinge Pins with Bronze Bushings.
Hi SMG,
I'd like a set of your hood pins/bushings. I have a 75 model with the big panel type spare tire carrier. I just had the OEM pins plated with yellow zinc since there were in good condition. Will your bushings fit the OEM pins in this vintage? I bought nylon bushings from Amamaya P/N 90386-20002 but they are 20mm ID and the original OEM bushings (which I still have 2 of ) are 16mm ID. If your bushings fit my OEM pins I'll take a set of those as well. If not, quote be the price for your full set please.
Hi SMG,
PM sent
Hi SMG,
I have a 75 FJ40 and live on the ocean in Alaska. Your SS pins & bushings will make a big difference for me in the long run. Would like a set of hood and a set of door.
Thanks. Have you expanded to ambulance doors?
I'd like an ambulance door set if you have some please. I plan on doing all my hinges (hood, front doors, etc.) eventually, but need the ambulance set to be able to put the doors on for now.
Mark
  • Like
Reactions: SMG
Just received my hinge pin set for my 64 FJ45SWB tailgate. They look awesome! Going to be much more convenient when it comes to painting. SMG thanks for taking the challenge on to build these, I feel others will probabaly be wanting a set too.
Cheers,
KevO
Have you started making a hinge pin for the early style 40 series hood hinges?
Unfortunately no, I have tried, but the early 2 ear Hood design would require machining on the hinge frames.
Thanks.
Bummer but I understand
  • Like
Reactions: SMG
pm sent
  • Like
Reactions: SMG
