Springover for $500?
Tulsa, OK
A local shop says they can do a springover on an FJ40 for $500 total. (No tires or wheels of course)
Seems like the last time I got quotes for this job they were closer to $2-3 grand.
If I remember correctly the double steering arm was $255 alone, not to mention the spring perches and torsion bar.
How do you think they do a S.O.A. for $500 bucks and would you trust it on your truck?
$500 for a shop-done spring over...
let me guess, they have LOTS of experience on the same lift on a CJ7 or YJ....
you obviously already know the lift is worth $2k or more if done correctly by a shop...don't set your hopes very high...
2badfjs said:
ask them to give you a list of what they plan on doing
i.e. cut and turn
steering issues.......all that fun stuff
I didn't get an itemized list but they told me that all the steering geometry would be corrected including turning the knuckles.
A side note, however, I have seen an FJ40 with a springover where the person just bent the tie rods to fit and the front and rear driveshafts nearly made a L when the truck was at rest.
thats about what i was quoted by a local shop for front cut and turn and rear axle perches. no steering mods or rear torsion bar, just the axle work and i know the owner. he went to school with my brother. it could be cheaper if i take the axles apart but i prefer to have it in the vehicle when hes doing it. he would do the cut and turn on bare axle housing for about $150.00 to $175.00
so yes get a list of what he will do and dont bend the factory arms go high steer set up.
pygpen said:
WTF is a torsion bar doing on a 40?
Torsoin bars are used on some IFS trucks....
My guesse is its a half assed hack job.
You need shocks, perches, drive shaft work, steering..... steering alone is close to 500!
do it right the first time....
PMK
I actually mispoke, I said torsion bar maybe I meant traction bar? I am not well versed on terminology.
New shocks.
New spring perches.
New brake lines.
New shock mounts.
New knuckle arm.
New spring bushings.
New (or modified) driveshafts
This is about the minimum that you can get away with.
You should also use new Ubolts.
Most people cut and turn.
Even for a bare bones conversion with a lot of things not addressed, there is no way that you can get a SOA done right for that price.
Mark...
Mark W said:
New shocks.
New spring perches.
New brake lines.
New shock mounts.
New knuckle arm.
Mark...
Can cut the spring perches off and reuse
can cut shock mounts and reuse
can add another section to break lines
can heat and bend steering arms
can reuse spring bushings
Cut and turn is just labor.
definetly need to have driveshafts lenghtened.
Yes you can do all this but you will have a piece of crap that is unsafe.
