- Thread starter
- #21
Ok - indexing ring, good name & bad design.
The objective to getting on the road would be to drive for a few weeks (I think) not just home. So with the CDL engaged and drive shaft pulled, we wouldn't need diff oil?
Isn't the diff spinning anyway with the short side axle in place?
On the diff housing access plate - I assume we would have to pull the diff to actually use these ideas of driving in the indexing ring. I think pulling the diff is beyond our skill level.
Other notes - this birf had blown up last spring and was repaired by some
shop. Anyway if you think about a birf blowing up and the axle flopping around in the tube, no wonder the index ring gets unseated.
To those folks who are thinking about letting their birfs go for 160K or so, think again. Even if you don't mind spending money on expensive parts, fixing something like this is a real pain.
lovetoski - when you say "pulled the diff 3 times" you don't mean pulling the entire diff do you? Sounds tough.
My current thinking is to start off planning on pulling tight with an inner seal puller and if that doesn't work then plan B would be to get it back on the road with the axle pulled. It then becomes a choice between driving the indexing ring back into place OR go with the drilling/tapping an access hole.
FYI - we had a heck of a time putting in the axle and it was after an hour of trying in vain did we notice the ring lying in the tube. Safe to say, installing the long side axle without the indexing guide ring is impossible (unless you use the access hole mod.
Besides the PHH, this is the second bad design I've seen on this truck. If there's only 2 I can handle it as long as I know about them before they are an issue.
Riley
shop. Anyway if you think about a birf blowing up and the axle flopping around in the tube, no wonder the index ring gets unseated. To those folks who are thinking about letting their birfs go for 160K or so, think again. Even if you don't mind spending money on expensive parts, fixing something like this is a real pain.
Riley
