Solid quarter glass leak
Vermont
So recently installed solid quarter windows since my sliders leaked like everyone else, along with the aluminum crumbling by hand.... My driver's side doesn't leak aside from the trim piece under the glass that I've siliconed twice now and I think my vent leaks too unfortunately. But on the passenger side the window leaks where the glass sits in the seal. It pools up in the bottom of the seal with no visual signs of water running down the glass or anything. The trim on the bottom leaks to but I think it just needs more silicone. So is there anything I can do to stop the glass seal from leaking like it is aside from putting window sealent on it, or finding where it's leaking from since I can't seem to find it? Exspiecally since that seal type doesn't require sealent. Also how do you test to see if the rear vents are leaking since you can't see them on the inside? Thanks for any help
It's a Toyota seal with glass I got off Rock Auto. I don't see how contacting ethier of them would fix my leak.
Easy solution
Pressure washer test and Lab approved
Rear Flip Up Windows - Land Cruiser Products - LCP
I just spent $400 on the windows and seals. I'm not dropping a grand plus on something like that, that will oxidize in a year from the salt here in vermont.
Sorry your new windows are leaking I was just offering a solution with perks.
FWIW our windows are $850 shipped for two
Panels finish is of the highest quality - 6061 aluminum, sand blasted, and powder coated and slow cured at 350°
After two years with 100,000 miles logged from Canada to the tip of South America zero issue with our finish.
Bonus THEY DONT LEAK;)
Testing, have someone help you with a hose to figute it exactly where water is coming in
Don't just blast water at it. Water runs downhill, if you start at the top, and water dogs at the bottom, it can be difficult to figure out exactly where it gets in.
Start at the lowest point and carefully direct a gentle but steady stream of water at things like the trim, bottom edge of window seal, top edge of window seal at the bottom, then the vent start at the bottom
Also, leaks can take a while to appear, it might take a minute or so of soaking each area before water tracks through a leak
You can see the vent giddy up from the inside with a mirror if the interior quarter panel is removed. It's probably not that though.
I thought mine was leaking too. Wasn't. It's got a gasket between the vent piece and the body with flaps of rubber that lie down flat. There are say 6 flaps, each attached at the top and loose at the sides and bottom. Works like a check valve sort of. Air out but nothing comes in because they naturally sit sealed up. If you remove the outside black plastic piece you'll see that, but you'll break that pieces mounting points doing it. Of course you could silicone it back on, but I wouldn't start there.
I already removed the louvers once and have them bolted at the bottom and siliconed at the top. On the driver's side the leak comes from that area and it's not the bolt holes its above it
You test my removing the rear paneling. Apply baby powder or something similar across the exposed metal, then run a hose on the outside of the window. This should leave a trail in the powder that can direct you to the leak.
Why not seal the the window with polyurethane sealant like the glass guys do?
Cut the tip so it’s small enough to shove between the rubber seal and the body and run a bead in there all the way around. This is how your windshield is sealed.
It would have been cheaper to just put new runs and a seal on your rear quarter sliders. I just did one of mine. It was so easy I think I’ll do the other one next weekend. I had no leaks but runs were so full of dirt the windows were difficult to slide. Leaking sliders isn’t a problem I read about on Mud. However, leaking belt molding is common.
It wouldn't have been cheaper to fix the sliders at all. And they could still leak later on. I installed the seal in the same orientation as the slidder seal. The seal doesn't leak on the body side it's the glass side it leaks on. I could use the polyurethane stuff I did have some from ahilw ago. Probably not good anymore but the seal shouldn't require it
Why would your sliders leak. I’ve had three 80’s and none of the sliders leaked. Maybe your rotten frames were to blame.
this is a good idea
There's a thread here (this year, I think) concerning waterproofing the rear windows (OEM), which should help you. I was going to nominate it for permanent FAQ status. The poster did a really good job. If I've saved the link, I'll post it here.
EDIT: this isn't the one I was looking for, but it does have all the info:
Water leak
Water leak
That was a good read with lots of info thank you sir
