SAS Solid Axle Summit #7 Official Page
Solid Axle Summit
SAS #7 Color Choices for Swag and Trail Flags
  • • Yellow / Mustard
    Votes: 12 13.0%
  • • Sky Blue
    Votes: 6 6.5%
  • • Pollux Orange
    Votes: 30 32.6%
  • • Spring Green
    Votes: 6 6.5%
  • • Capri Blue
    Votes: 7 7.6%
  • • Rustic Green
    Votes: 31 33.7%
  • Total voters
    92
  • Poll closed .
Im taking ducking to a new level.
While you kids have been fixing transmissions, upgrading suspensions, and tweaking flux capacitors to prep for the ride to the SAS, the Bourbon Sponsor here in Northern MI has been hard at work to get everything he needs for the long trip West in August. The custom barrel head from Maker’s Mark arrived today.
More brown liquid goodness to come....
I think I figured out a vanity plate....
"NO DUCK"
I’ve checked and that’s available in my state as well as “DUCK OFF”
I don’t want to lose my antique plate though
Chasing a noise 🤷‍♂️ The rear third is in good shape as are the axles and drive flanges
I thought I had everything to put it back together but the hub seals in my stash are for the front so waiting for those to come in from Cruiser Outfitters.
I can work on the Hydro assist while I'm waiting, replacing a 9" ram with a 10" ram for more turning radius;)
Made by Good old boys in Texas 😁
@Broski whats the noise?
I only hear it at 60-65 MPH and let off the gas and the drive train is slack, if there's back pressure I don't hear it either.
I put my good used spare drive shaft in no change.
Now I'm thinking transfer case but there so dam bulletproof on a 80 🤷‍♂️
I have the same noise in my 80.
On power, nothing
Off power/driven, nothing
Neutral load, sad sounds.
I was thinking t case as well.
Drive line mechanic buddy thinks it might be front pinion bearing.
On power, nothing
Just went through front third Last year, so both thirds checked and good 🤷‍♂️
Been chasing the noise for over a year now :(
Well s***. I didn't do it, but my tcase was opened up by a PO. Fluid looked great when I dropped it a couple of weeks ago. I ruled out the t case because of that... BUT, the hi-lo lever does increase in vibration when the noise is happening. Which doesn't mean much.
I keep forgetting to check u joints
80s with tall lifts and uncorrected front caster make for some angry front DSs. This is well-documented in the 80 section - as are the solutions.
HF2As have a little output shaft wobble at slack throttle due to no torque going through the center diff. This increases with age as the spiders wear in, as the center diff output gears are what locates the "free end" of the output shafts. Putting some torque in it causes everything to tighten-up and center-up. Part time trucks see this to a lesser degree as the worn spiders get replaced with fresh, solid parts that tighten everything up.
Time to go part-time @Broski!
Did you crack open the locker and look inside ? My Detroit made bad sounds it had a few cracked teeth inside . you may have wear ?/
I have a 4" lift. Could be front drive shaft angle too.
I have a brand new DC front drive shaft and less then 3" of lift with 4" of castor correction.
As I'm sure you know the OEM locker is totally different, but yes it was opened up and everything is good !
I have the same problem, but it’s worse than yours it sounds like. I’ve replaced/rebuilt everything. Angles are good. All that’s left is the T-case. I replaced the rear output bearing (since it’s quick and easy) so that’s ruled out too. The issue isn’t there if I drive it in FWD with rear driveshaft removed. I’ve put up with it for years at this point, but it really sucks coasting down those long grades out west.
At this point I figured the t-case as well
Probably just live with it for now as it doesn’t get much highway use.
What @Zjohnsonua said make a lot of sense
