soa vs 4 link
Plainview, Texas
I'm trying to decide whether to go with a soa conversion or a 4-link coilover system on my 40... any opinion on what is better which sux etc?
yes,
search....
there was a thread just last week on the topic.
what are you fabbing skillz?
well i've been welding since I was about 13 years old and my dad is a mechanical engineer so I can pretty much fab up anything
I wouldn't be able to afford coilover right now but if it is worth it, i'll wait and save up a little more for the 4-link
4 link would be the best way to go...save your $$$
When you start your build, be sure to make a thread on it and post up pics out here.
Good luck!
-Steve
I am going through this right now. I had never done a 4 link before, so I spent days researching it online and in books. I thought I had a very strong grasp of what it takes to build a "good" 3 or 4 link suspension. After 2 versions I think that I have a good final product, but the cost is significantly higher. You can SOA your rear suspension for a couple hundred dollars, a 4 link with coilovers will costs $2000+ Is a 4 link better? I think that would depend on your use. If this is going to be used mostly offroad, then yes, but if it is going to be used onroad you will have to have a swaybar adding even more to the cost. I would suggest you talk to a vendor and get a good idea of how much it will cost (coilovers, links, inserts, joints, brackets and tabs, bumpstops, etc.) and that might help you make up your mind.
Ryan.
mine is SOA front and 1/4 ellip 4-link rear....relatively inexpensive and it performs excellent...balance performance, and 60"+ of combined wheel travel.
My next rig will be 4-link airshocks in the rear and 3-link/panhard with airshocks in front.
Airshocks are "only" $1000ish a set, versus $2000ish+ for a set of coilovers. "good" links are $100per x 8....or more, depending on what ends you choose...add in the tabs and a lot of fab time and the SOA begins to look like a breeze.....and it performs well too.
ok thanks for all your input... I have plenty of time to make up my mind but I just don't want to do something cheap that will end up costing me more in the future...
