SOA question
Chilliwack, BC, Canada
Hey guys, i have a 1982 Bj42 and im starting a spring over on it. I plan to do a cut and turn in the front and angle the back for the right driveshaft angle, my question is how many degrees should u angle the front and the back? thanks for the help:)
What size tire are you going to run?
Castor angles should be anywhere from 3 to 5 degrees. Pinion angle on front should be set while axle is on vehicle with the vehicle weight on it.
https://forum.ih8mud.com/showthread.php?t=54253
And check out the Tech Links section. That is where I learned how to do mine
Most people, myself included like to go for 5deg of caster in the front end and the rear has no set angle. You aim the pinion at the transfer case with the full weight on the truck to find the correct angle.
Sounds like you should do more reading about SOA before you begin.
ouch!!!
do what troll said, rear is simple as pie, the only way to learn is to read and then trial and error. its not as hard as one might think. have fun with it. i did, for the most part :cheers:
I personaly think you should aim a little low of the t/c. The trucks I've worked on have all settled in and dropped an inch or so.
aw
i am doing spring over in the front. got a kit for proffitts. they tell you with full weight on the axle. the pinion should be pointed lower than the t-case yoke. a 10 to 13 degree angle should accommodate most drive train combinations.
