Slider build ??? (pic's)
Kansas City, Missouri
OK,
I have looked at all the pictures I can find of Hanna's sliders and just can’t tell by the images I see. I'm getting ready to build a set of sliders and really like both Hanna's and Slee's design, but cant afford to purchase new and have the equipment to build a set for myself and a friend. I will first state that if I had the funds to purchase from Hanna or Slee I would, but no luck...
Anyway, I wanted to ask those of you who have HQ sliders a few questions. First question: Does the 2x3 main rectangular tube sits directly under the pinch weld or does it sit just outside the pinch weld? Question two if you don’t mind measuring for me is the distance that the 2" DOM out rigger is from the main 2x3 tube. I am looking for the measurements from the outside of the 2x3 tube to the inside of the 2" round tube? Last question for those of you who own Slee's sliders, I notice that he uses steel channel NOT TUBE to connect the slider to the frame. It looks like it is 1x2x3/16 channel, but not for sure can someone verify for me??? I want to make sure I have purchased the correct steel before welding it all up.
Any help would be appreciated and I plan on doing a detailed write up on my build with pictures to help others in there quest to build there own sliders.
Thanks
Zane
Zane,
Take a look at the plans for George's sliders. He has detailed drawings with all the measurements. Several have done those.
I don't know about the HQ sliders, but most of the "off-the-shelf" sliders have the rectangular tube positioned the other way... horizontal ... I'm guessing to maximize ground clearance.
Be sure to leave clearance between the body and the sliders. There is more body flex than you might think.
-B-
I second that. I have one of the first sets of Solidrockoffroad.com's 80 series sliders, welded a little TOO close to the pinch weld. I left .25" clearance and ended up needing to bend the pinch weld up and away from the slider to keep it from banging around. I recommend at least .5" of clearance.
I'm on the finishing end of building a set off of George's design. I had the pieces cut, welded them myself, and am having a step rail and special outrigger bent since I have one cat and his design works with the OEM two.
If I were to powder coat my sliders, I would be at the cost of the Hanna or Slee sliders. The pride in "I made this" has diminished quickly. I know that doesn't answer any of your questions, just a thought from someone that's been there, done that.
this brings me to a question now that there is a 55 sitting in my driveway.... why do the 40 and 55 guys weld sliders right on the rocker panel instead of welding/bolting outriggers to the frame? Seems like the rocker panel would not be strong enough to hold up the weight of the rig.
Excellent advice!
-B-
I "think" I have figured out that Hanna's Sliders are just outside of the Pinch weld. If someone knows for sure let me know. Good advice on making sure that I leave enough space between the slider and the rocker due to body flex I will make sure to account for that.
Any one know what size channel Slee uses on his sliders to connect to the frame?
ZZ
What was the $ estimate to powder coat?
Aside from the whole issue of copying somebody's design..... Unless you are super quick and skilled with the fab work, It has been my experience that by the time you have it all together there is very little trade off in building your own. Its trial and error for the first set of anything you make and just not worth the headache IMO. I have everything in my garage to build a set for my 62 but will be giving Jim a call instead. However, if you have serious skill draw up a design and git r done. I personally work at 1/10 the speed of buckroseau's pace.
My tallies so far are:
And that doesn't include cost of the welding supplies or labor. Many have ~50 hours in their first set of custom sliders.
-B-
Not to bust your balls, but both Hanna and Slee spent time and money figuring out their best design, which may be kind of "trade secret".
OK,
I think my balls will be just fine. All I'm looking for is what the experts use for steel size not specific disign other than my question of how far out the round tube sits from the main slider, but that was just to support an idea I have for my outer rail. I see that George uses 2x3 to connect the rail to the frame, but both Slee and Hanna look to be using considerably smaller stuff. I would love to maintain stringth while keep down the weight as much as possible and figured that asking would be no big deal but understandably now I know differently.
Attached is a picture of a pair of Slee's Sliders for a 100 searies that looks to be using 1x2 channel, but again I was just looking for clarification.
thanks
Zane
I am by no means a master fabricator, but i had access to a plasma cutter and welder, and a harbor freight bender. I did mine over 2 wekends and painted them myself. i didnt end up having more than 140 dollars in material. Georges design is pretty much as good as anyones. Mine are welded directly to the frame and have hald up great. the only peice i custom made was the one piece that went around my Cat. My brother did the same thing. I really think as far as fabricating something these are not that bad. get out some cardboard, some scissors and start mocking it up....
OK,
thanks
Zane
dont over analyze this to death. its 4 outriggers (3 of 4 are super easy) and some 2x4 steel box. error on the side of to beefy and crank up the heat on your welder. you will be fine if your going for function. IF you want some super nice looking great performing off the shelf sliders, call mark at metal tech, they look like the best ones being made right now.
Q:All I'm looking for is what the experts use for steel size not specific disign other than my question of how far out the round tube sits from the main slider, but that was just to support an idea I have for my outer rail. I see that George uses 2x3 to connect the rail to the frame
main rail: 2x4x.120
mounting plates 1/4x3"
outriggers" 2" round tube
gussets 1/4" plate
hardware grade 8
your outter tube from the main rail is totally up to you, i've put them 6" out, and i've put them 4.5" out. it just all depends.
