Slider build ??? (pic's)
sliders are not rocket science. Us in this 80's forum often do too much hypothesizing and too little doing. you dont need measurements. the slider is sitting below your rocker and there are lots of pics/posts of builds/instals. do the following:
1. make the frame mounts first if you want a bolt on design
2. bollt the newly fabbed frame mounts on the frame where they will be
3. hang the slider piece where you want it with jack stands like you have done (even better tack up a couple of temporary outriggers from the frame to slider rail-cut this off when done)
4. now cut cardboard templates to connect your mounted frame brackets and slider rail
5. use templates to help cut out the actual outriggers.
6. tack it all together.
7. now unbolt the frame mounts and weld it all up (if you didn't tack well stuff will shift with final weld so you may want to weld up the 2 endmost outriggers first and recheck fit before you weld up the center outrigger)
sell the material to your roomate, go buy Metal Tech's sliders.
or go park next to a huge rock, and see where it'll hit, move it out to there, or round it up to a safe number you wont forget. I doubt a half inch or so would change too much.
Any one know what size channel Slee uses on his sliders to connect to the frame?
ZZ
3/16" plate steel bent into a channel.
Metal Tech make the u go up 'U' rather than down 'n', which gives a better surface for hitting rocks.
That 100 series you show has to have the braces from the outrigger to the mounting plate, that the 80 series doesn't due to the shape of that channel.
Georges design requires outriggers to be cut in at an angle in two directions doesn't it?
I'm all for simple and strong. I used 2x2x1/4" tube, accounted only for the frame angle, so the outriggers are flat (horrizontal). I then cut a clearance 'v' for the pinch weld. Using 1/4" full tube rather than a channel, I'm not worried about the loss of strength from the 'v'. I also have braces (simular to that 100 series pic.) from the outriggers to the frame plates.
Course, mine don't get wierd untill you get to the slider it self being a trapizod of 8", 2", 2" and 3" plate, giving a smooth surface to slide on, no way a rock can wedge in the tubes. Oh, and they rotate down into steps.
I only paid $200 for all the steel, and have tons of extra left.
