Simple electrical question...
Bozeman, MT
I am blowing fuses on my rear tail lights (brake lights work fine). But my rear tail lights are going out as fast as I can get a fuse in them.
I can hurt myself turning on a light switch in my house.
Where should I even star with this?
I am assuming since they are blowing just the one fuse, they are on their own circuit?
Bulbs, then wires?
Thanks-
Rezarf <><
all my turn signals are connected.
I didn't know there was a fuse for just rear tail lights.
I just had a short in one of my front tail lights. I found it buy disconnecting each turn signal one at a time. My panel light would turn on dim when I turned the key on with the lights off. When I turned the lights on it looked normal.
look for defective ground first
rusty_tlc said:
:confused: To blow fuses you need a path to ground.
Precisely, you have a short to ground. Lamps(bulbs are what your wife plants in the garden[smart a** electrician comment]) will not cause your issue. Somewhere in the path you have a hot wire going to ground. Best would be to start from one end and work your way carefully to the other.
REZARF said:
Thanks I will start checking grounds.
Rezarf <><
I think you need to start looking for a short to ground on the power lead. Your grounds are probably okay.
A quick check, remove the lamp and measure the resistance between the contacts. It should be open.
It isn't a bad ground problem. It is an inappropriate ground problem, more commonly known as a short.
The first thing to do would be to bypass the switch and see if the fuse blows. Disconnect the green wire at the switch and connect it directly to the power wire to the switch, which is green with red stripe. If the fuse doesn't blow and the lights come on, then the short is probably in the switch. If the fuse blows, then it is probably a short in one of the wires. You could help narrow which wire by removing all the tail light and running light bulbs and installing an amp meter in the fuse block in place of the fuse. Reinstall the bulbs one at a time and measure the current. If you find a bulb that sinks way more current than the others, you have found the wire that is shorted.
Besides the tail lights, all the running lights are on the same circuit, so they should all go out if the tail light fuse blows.
It could also be due to an overload caused by having too many lights or bulbs that have too much power on the same circuit.
Thanks Pinhead,
That helps out a lot. I haven't checked my front running lights as I got pulled over for not having tail lights, I will check up there for anything obvious too.
Thanks agian everyone-
Rezarf <><
Well, I have the ground issue isolated to the front drivers turn signal/running lights. I have always had grounding issues there.
Is there a way to create a new ground by running a wire off the ground wire and back to a known good ground in the engine bay or am I asking for trouble?
Clueless electrician, Thanks!
Rezarf <><
Yes, you can do this to cure a problem with a bad ground, although you usually only have to run it to the frame or good sheet metal.
Just don't expect it to help cure a problem with blowing fuses as this can't be caused by the lack of a ground.
just an idea, but you might want to check your wires where they run through the body panels and underneath the body where they would contact the body or frame. it could be the hot conductor has worn the insulation off at one of these spots. not an obvious fault but it could be inconsistently shorting out.
also if you have a bad ground and the conductor isnt too corroded just clean up and bare the metal where it attaches, paint is an insulator, if your worried about corrosion at this place just tighten up the new ground and apply paint on top.
Rezarf <><
*how* did you narow it down exactly? What is it that makes you think that light is your problem?
If you stopped blowing fuses when you disconnected that running light (but not the turn signal cause it's on a different fuse) then you probably have a short in that light somewhere. Probably your running light wire (outside or inside the housing)
Also, is there actually a ground wire in a factory front marker light??? white with black stripe? I don't know cause I've never looked at a FACTORY lamp. I have the CCoT things and there isn't a ground wire.
Well, I got it the tail lights to work this morning by unhooking my front turn signals.
However, after messing with my rear cross member (drilling) I am blowing fuses again, so I guess I will be looking there tomorrow...
uggg, I hate electrical issues...
Rezarf <><
ditto Pin_head.
and... um.... drilling = blown fuses sounds scary to me :D
sounds like you may have 2 issues (or created a new one :D)
get under the truck and follow all the wire loom to make sure you didn't drill into it or that it isn't just worn somewhere. Everything should go from about your heat blower box in the engine compartment, down the PS frame rail then across the *bumper* frame member.
