SHUSH's 71 FJ40 "ol blue"
Take your time because the glue can be a mess and I would suggest getting the doors seals and door at room temp instead of cold.
Roger speedn will do. I did the doors on my last truck and putting that rubber in the sun helps plus fitting dry to make sure I know where it lines up.
Anyone experienced?
What's the best way to find faulty wiring? Work my way downstream?
Disconnect the lights, relay, and switch, put in a new fuse to ensure its good.
measure the voltage at the battery, then at the fuse, then at the relay, then at the light connectors? If there is a big voltage drop compared to the previous reading then the short is just upstream?
Does that make sense?
I would start at the fuse box - if OEM, the fuse holders have a good chance of being very corroded
Warning........heavy tech discussion
I have a frozen pin on the drivers side lower hinge......DONT panic, I removed the hinge ( 3 bolts on door and 4 inside kick panel) and hinge/pin are soaking
That is all.
My color with the light grey just looks killer
But troll holes new version has 2 side windows and 2 rear side windows ( like hard top) with 1 rear window
It is. I miss typed. 2 side windows is Oem. Marshall offers 1 side window, per side, for better vis on lifted trucks. I love this look.
if you are letting the grey one go, I would be interested
Anthony is selling a tan one and, since I don't have bows I could maybe buy later bows to make them work....
I talked to him - the later model bows are rare as hen's teeth, he doesn't sell the bows for this top :frown:
not mine just a pic to show color contrast:D
yeah did some research and realized same....about to pull the trigger with Trollhole and Reel Steel
Adjusted idle finally and she is back to purring. Do aisin carbs "fall out" that quickly from being tuned correctly?
Maybe she is just running well because I bought her a top today?
Wife just sent me this......guess I need to get some paint
Todd Ogino with Real Steel had this at my door in 48 hours! nuts
I've seen references to FSTs having a dome light on dash? Is this one?
Mock up
Will it get through the garage door that high?
Looks good.
Definitely not the original dash light. MUD search "Darth Vader light" for a pic of the OEM.
B Pillars aren't seated
Thanks
