Sheeeeeit!!
If that photo of your fuel sender is correct, then you do not have it oriented correctly. Those two empty mounting holes should have matching holes in the tank. The sender only goes on one way that will expose all five mounting holes in the tank. If you can not find the gauge and sender you want here, then it does not exist.
http://www.egauges.com/
Ok. Update on the JC Whitney sender/gauge combo. The mounting plate didn't fit the tank posts. So, I fabbed it with the sender plate I got from CCOT. I had to shorten the mounting bracket that the float sits on because the sender had to be for a semi-truck tank. Anyway, it still didn't work. So, then I started new wiring. I used an open spot on the fuse panel for my + then I grounded the sender on the body, then of course I ran the "s" to the gauge. Didn't work. Then, I took the dash off and looked behind and there was what looked like two female LC stock connections that all of the gauges are supposed to be plugged into. I think these may be faulty or something. Also, the gauge is routed inline with the tach which is screwed up too. I'm going to get another sender from CCOT and a gauge to match. Where could I get a gauge with a matching ohm range?
Got my sender and gauge in today and tried to install it. I think there might be an issue with my electrical system as a whole. I hooked the gauge up like this: + to the pos side of the battery, - to the neg side of the batt, s to the sender. I grounded the sender to the frame. I'm still getting nothing. I don't understand what is going on.
X2 here gauge short or ground causing full reading
the guage probably shouldn't be grounded becomes a short in simple terms should be power in guage ,power out of guage to sender, sender to ground no ground at the guage i could be wrong my .02
Pin_Head said:
- 1 on the ground.
If the ground was bad it would read empty, not full. The gauge is "grounded" through the sender.
Maybe an inappropriate ground, AKA a short.
The ohm rating for an aftermarket sender I originally bought from CCOT is:
Tank Full 2.1 ohms
Tank 1/2 Full 4.5 ohms
Tank Empty 6.5
I bought a VDO gauge from egauges.com. It's the first one and the rating is 0-90 ohms Here is the link:
http://www.egauges.com/vdo_mult.asp?Type=Fuel_Level&Series=Vision&Units=E
These should work fine, right?
I hooked up the VDO gauge to the sender that came with it as a kit and this is how I hooked it up.
Gauge:
+ straight to the battery
- left that unhooked because I grounded the gauge through the sender
s sender
Sender:
to gauge
ground on mounting plate
The needle did something different....it came up to Empty and sat there until I took the ground off. I know I had gas in the tank.
Other things:
I made sure the float didn't interfere with anything in the tank
My lights work
turn signals work
What gives? :mad:
Back to the gauge business.....gauge is reading semi-correctly but falls to Empty while driving every once in a while. It rises back up to the semi-correct reading. What I mean about the "semi-correct reading" is when I filled it all the way up it went to 3/4. It took a while for it to start to show that I actually using gas. Initially when I bought the VDO 0-90 ohm gauge it was reading backwards. This made sense so I bought the same gauge but it was 90-0 ohm. I would just like to be done with this issue because it seems like I have enough posts for this one issue than with a frame-off restoration. I mean come on already.
Then you have an intermittent wiring connection someplace, a poor quality sending unit or instrument. Are you using the stock wiring? Are you certain that the ground lead that should be connected to the sending unit is attached to a good ground someplace else in the system along with being properly attached at the sending unit? Are you sure that the signal wire from the sending unit to the instrument has continuity? Have you stopped by Radio Scrap to pick up a ten dollar multi-meter yet?
Well.....
"Are you using the stock wiring?"
No, total re-wire with an 21 circuit EZ Wiring harness.
"Are you certain that the ground lead that should be connected to the sending unit is attached to a good ground someplace else in the system along with being properly attached at the sending unit?"
Two grounds....one to the sending unit plate and the other is the ground for the gauge which is behind the dash on the body.
"Are you sure that the signal wire from the sending unit to the instrument has continuity?"
No interuptions in the signal wire...it goes directly from the sender to the back of the gauge marked "S".
"Have you stopped by Radio Scrap to pick up a ten dollar multi-meter yet?"
Actually it was a $20 one from Home Depot.
If I remember correctly from the last time I worked on my 79 40, shorting the sending unit it will read full Two wires coming from the gaugeto the sending unit.. Another words zero resistence means you have a full tank. If it is reading full i would disconnect the instrument cluster and see if it goes to to empty. If does not go to empty I would suspect the gauge being the culprit.
If you used an OEM Toyota gauge and an OEM Toyota sending unit you'd have no fun at all.
Your 'aftermarket' sending unit is probably flakey. You get what you pay for. Get a proper multi meter and use it as a gas gauge for a week to see what the sending unit is doing.
You have three unknowns (sending unit works? SU matches gauge? ground path is ok?) and only one equation. Start at the beginning (Sending unit) and address the three problems one at a time.
Oh no..I have a brand new aftermarket Toyota sending unit from CCOT. I was having similar issues before I replaced it. My engine isn't grounded to my frame or the body. Could this be the culprit?
Going back to Pin_Head's suggestion of a short causing a pegged gauge is there a possibility that the (+) positive terminal of the gauge itself is making partial or intermittent contact wih the instrument case?
If the gauge is suspended within the case and it's contacts are insulated as they pass through the case even a slight misalignment of the contact within the hole, or a loose nut on the contact post might result in a current flow from post to case, thereby shorting the gauge. A low voltage short would give a full reading.
