Sheeeeeit!!
wantatlc said:
well, in basics, the gauge and sending unit have Ohm ratings on them. So's - you need those to match up between the two.
need to know more about your sending unit and gauage cluster/setup to comment more.
for example, my original gauge in the dash would not work with my aftermarket sending unit (diferent Ohm ratings) so I had to change the gague as well.
You can not just put an after market sending unit in and expect it to work. When I started building my new instrument cluster, I looked for a fuel gauge that was compatible with my two factory senders. I could not find a match and had to buy senders that worked with the VDO fuel gauge I will be using. One other issue I found while looking into this is that there are any number of senders with different resistance ranges from empty to full. There are also some senders that reverse the output.
Ok. I bought the sender from CCOT for a 72 FJ40. The gauge is a basic Autometer from Pep Boys. The ground is located on the sending unit plate that seals it to the tank. The only thing I can think of is that I haven't replaced the wiring that goes from the gauge to the sender. Because POS PO #2 built a rats nest under the dash I am contemplating the 21 circuit ezwiring harness to fix everything.
It's frustrating because I don't know how much fuel I have.:princess:
Yes. I tried that. Touching the connector wire from the gauge to the connection post on the sender. The meter dial jumped to full everytime I touched it. Full...empty Full...empty Full...empty
The CCOT sender will duplicate the OEM ohm range which is from 17 ohms at full to 120 ohms at empty. The Autometer gauge should adher to their standard of 33 ohms at full and 240 at empty. Even if the wiring in your rig is perfect the Autometer gauge will read about half full when the tank is completely empty. Also, although unlikely, it is possible to install the sending unit in the tank in such a way that the flot hangs up on the side of the tank and will never drop down. Have you checked to ensure that the float has the full range of movement inside the tank? Put an ohmmeter on the sending unit and see what it reads without any wires connected.
Interesting. I actually checked that because I didn't remember how I placed it in there. Anyhow, the flot points to the back of the tank. Also, sometimes the gauge will look like it is working and then it'll shoot back up to full. Strange.
Have you tried putting a new ground wire to the sender body? Put a new sender in that is compatible with the ohm range of your Autometer Fuel gauge. Autometer makes fuel gauges with no less than 5 different ohm ranges; 0-30, 0-90, 16-158, 240-33 and 73-10. You need to know which ohm range your fuel gauge uses. It may be that you are using a gauge that is totally incompatible with the sender. If that is the case, there is nothing short of putting in the correct sender that you can do to correct this issue.
well, the gauge seems fine as the unit responds.
the sending unit is brand new so likely fine.
you claim you put in the sending unit correctly so the float can float free.
so if in fact the CCOT sending unit can work with the Autometer gauge as Medusa claims, then it must be wiring. (FWIW, One of the reasons I bought a complete kit [from JC Whitney of sending unit and gauge] is just to be sure that it all worked togther perfect. In the end, I even added a 2nd sending unit to the same gas gauge and put in a toggle so I could run 2 tanks (front and aux) off 1 gauge using the same brand, model sending unit.)
I would try to bypass all of the wiring that exists (use alligator clips and spare wire) and diagnos it that way and ground the sending untit to the seat rail to be sure it is grounded as a test as I had issues with my bolts not grounded great when bolting the sending unit down since it cannot ground due to the cork or rubber gasket between the sending unit and tank rim and counts on the bolts for the ground.
I would try to bypass all of the wiring that exists (use alligator clips and spare wire) and diagnos it that way.
The Autometer gauge will never give the correct fuel level using the factory sender. The ohm range of the sender does not match any of the ohm ranges available in an Autometer Fuel Gauge.
that is what I eluded to in post #10 that there needs to be compatibility. Then, when I read Medusa's post #26 - he says that "The CCOT sender will duplicate the OEM ohm range which is from 17 ohms at full to 120 ohms at empty. The Autometer gauge should adher to their standard of 33 ohms at full and 240 at empty." - which I took to mean that the sending unit and gauge will work togther, but then I reread and see that it then says "Even if the wiring in your rig is perfect the Autometer gauge will read about half full when the tank is completely empty." which seems to contradict the previous statement. seems :confused:
I regret that my response was ambiguous. If you read carefully (and note that "their" refers to Autometer) you should understand that the Autometer numbers I listed are about twice that of the OEM Toyota gauge. Consequently, as stated by others, there is no way the Autometer gauge will read correctly with the Toyota sending unit. Furthermore, as noted by bsevans, the Autometer ohm range I listed may not even be the correct one for this particular gauge. Not knowing which exact gauge was installed, I pulled the "generic" Autometer numbers. The bottom line is that there is no way the Toyota sending unit can be used with an Autometer gauge and produce an accurate result. If you use an Autometer gauge you need to install an Autometer (or other aftermarket) sending unit that is designed to work with the gauge.
which is pretty much what I pointed out way early in post #10 and #17 :flipoff2: :)
Here are pics of my sender and gauge. I stand corrected on the type of gauge I have. It doesn't have a brand on it. Also, the ignition is off as well. The sender again is a 72 FJ40 stock brand new from CCOT.
still a good chance of an incompatability between CCOT sending unit and ??? gauge? why do you not know what gauge you have if, as per post #1, you just bought it all new?
that being said.....
1. where are the 2 other mounting bolts on the sending unit? they can help with ground (and keeping the cork or rubber gasket inplace and fuel from leaking). those other 3 bolts may have iffy ground contact with the teeth in the tank.
2. did you rewire from scratch as mentioned before to the gauge by just using quick jumper wires and bypass any wires pre-existing to rule out bad old wires?
also, at least on my aftermarket setup, gauge still reads correct whether rig is on or off.
FWIW, I bought 2 of these kits from JC Whitney (sending unit you can adjust height and it has a compatible gauge) and they work perfect. Might consider going with a complete set and send back the CCOT.
(BTW, a better image would be the back of the gauge with the wiring, not the front :) ) - but even that is obvious as you said there was a + - s (as on most aftermarket gauges do) BUT also, weren't you saying that is shows FULL and yet this photo shows EMPTY???
Yah, I hear ya. Well, I tried bypassing and using the fuse block for an alternate mode of juice to the new sender. Actually, the gauge in the pic is the original but it still did the same s*** as the brand new one. I might just save my self the hassle and get the kit like you were saying. I'm tired of filling up with gas when I don't even really need to. Thanks.
I feel you.
way back in '05 I went through all of this here as well. In the end, just going with a new complete, compatible setup was the fix. I really wanted to salvage my original gauge, but it was a no go no matter what we tried, so I just got the set (which had the side benefit of adding an additoinal sender in another tank and running both on that 1 gauge)..
Since you are already using an aftermarket gauge in your own diamond plate dash, and are not trying to restore with original stuff, then just toss it all and get a set like the one I showed you and you should be good to go.
BUT.. still get those other 2 bolts you need.... gotta have those :)
Thanks for the info. Yah know the crappy thing is there weren't any posts to run this thing through except what you see. Also, around my tank always vibrates when I start the LC. So, naturally it sounded like the tank so I tried to hold it down to stop it if it was that and the whole MF moved a little. I could probably get straps from CCOT, right?
